What is this code and how do I clear it??? I was trying to bring my Haimer to the spindle to set up my first part and it looks like I’m locked out for some reason.
__________________ 2008 Haas VF2 OneCNC XR4 |
| I have financed a few machines thru Haas and they put a "lock-out" timer in the control in case you don't make your payments. I'm wondering if this is the code you are talking about. |
| Are you absolutely, positively, 100% sure you didn't change a setting or parameter that may have done this? What exactly were you doing when you got this message? Can you not do a tool change? If you can't, can you jog the machine with whatever tool is in the spindle? Will the machine home using the power up button? |
| I also have a newer HAAS that has a control panel lock on the side. It's an actual key to prevent my operator from tweaking the program or any settings. I've never used it so I'm just guessing but if you also have a newer machine, you might check if the "key lock-out" is active if you have one. |
I suppose I could reset all the setting back to the factory set up. But isn't the settings for user preference? I went through the settings and the ones that appeared to have anything to do with tools and changed them and it didn't make a difference. I can: Power Up and Restart Hand Jog Spindle Warm Up program will start. When I go to: MDI Offset T# ATC Forward I get the MACHINED LOCKED warning in the lower left hand corner of the screen. Yesterday I did check my SMTC oil and was in the housing where the oil is filled and installed a filler tube but nothing goofy happened like slipped wrenches, didn’t drop anything down in there to cause any concerns. I’ve worked as a mechanic, I’ve wired houses, cars, motorcycles all around fab guy, so I’m certain NOTHING was amiss when I was in there. I’m just saying that to indicate I wasn’t fumbling around in there to cause any damage, I do crap like that all the time. I just pulled the cover off the top of the SMTC cabinet and rechecked wires and nothing is going on. No loose wire, no damage, I wonder if there is a reset for the tool changer??
#10
#11
According to the haas tech guy, you should never ever have to add oil to the CAM-Box aka SMTC. If you do, then you have a leaking seal and must replace it asap. Also you should know, the oil that goes in the CAM-box is special and is different depending on which model year you have. I have a couple of 12 year old machines out there that have never had oil added to the CAM-Box so I trust my techs advise. That's why there is no "fill hole" but not related to your machine lock condition. |
#12
| Problem- Locked out! | M99 Dan | Bridgeport and Hardinge Mills | 1 | 07-09-2010 09:13 PM |
| Edit function locked? | DDLES | Haas Mills | 1 | 01-09-2010 03:17 PM |
| Need Help!- locked out of my fadal | sec1964 | Fadal | 2 | 03-23-2009 03:19 PM |
| locked programs | stevo1 | Fanuc | 0 | 07-09-2008 11:11 AM |
