Old 08-11-2005, 10:39 AM
ap-machine is on a distinguished road
' 04 VF 4 Rough Tool changing
Hello,
We currently purchased an 04 VF 4 and practically from day one there seem to be a problem with an extremly rough tool changing.
After any end mill or milling head work (side milling / face milling) during the tool changin process (umbrella type) the tool is being "ripped" from the spindle making a loud popping sound. The local HAAS service claims that they are aware of the issue and will monitor, but im affraid that with my luck the thing will brake as soon as the warranty is up.
Has anybody experience similar problem? Are there any solutions (other then service recommended light lube on the tool taper surface that makes no difference)
Peter
Old 08-11-2005, 11:07 AM
Rough tool changing
We have several Haas machines that sometimes behave this way; it seems the tool is being pulled out of the spindle by the tool changer as the spindle lifts. This occurs most often using tools that are taking heavy cuts (around 100 to 120% spindle load) for a long time. It occurs most with regular helix mills but not as much with high helix mills and I think it is just the taper snugging in really tight under prolonged load and high helix cutters prevent this because they generate a strong down pull. We keep spindle and tools clean and lubricated to minimize it but for some programs we have had to put in a dummy tool change to reset the taper in the spindle. On one machine we put a reserve air tank downstream from the pressure regulator on the machine. The normal operating pressure for the tool changer is 85 psi but during a tool change the pressure can drop around 20 psi below this because the regulator itself constricts the flow. With a ten gallon reserve tank the pressure drop is less than 5 psi and tool jams in this machine rarely occur now.
Old 08-11-2005, 11:36 AM
HuFlungDung's Avatar
Moderator
How do the tool shanks look after many changes? Are there any outstanding blemished spots that might indicate some kind of defect in the spindle taper?
Old 08-11-2005, 11:47 AM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
If you have a defect in the taper, its been my experience that the tool actualy comes out easier. Although this is a poor solution do to the increased TIR of the tool because of what amounts to poor taper seating.
We Have done something similart to geof and increased the air line size going to the regulator and replacing the regulators on the problem machines with a better (higher flow) regulator.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 08-11-2005, 01:49 PM
Thanks !!!
I will put an air tank (actually have a spare one) next to the machine and try to increse air pressure too.
seeing all these replays - are we saying that HAAS actually refuses to acknowledge that there is a problem with the tool change?
peter
Old 08-11-2005, 02:36 PM
I think it is not really a problem with the Tool Changer but more a problem with the air powered tool release cylinder. I think if they put a high flow solenoid valve at the cylinder, enlarged the air line going from the regulator up to the solenoid valve and had either a high flow regulator or reserve tank on the 85 psi line the problem would be solved. Except maybe for the times you let a hot spindle cool down overnight with the tool still in place from the last cycle. Then you have real fun.
Old 08-11-2005, 02:49 PM
I agree... solution seems very simple and inexpensive - one would think that HAAS would address it promply.
Does the problem also exist with that high speed arm tool changer?
luckly we are being very particular with the overnight shut down - always leave it toolless ..
regards
Peter
Old 08-11-2005, 03:22 PM
Send a suggestion to Haas. They have address and email info at
http://www.haascnc.com/custserv_SUGG...t.asp#custserv
Old 08-11-2005, 10:50 PM
crayner is on a distinguished road
Do any of you guys run an air dryer on your air lines? I'm thinking that maoisure could be the cause of this - I have noticed it on my vf2ss been told it was a non-issue... it's out of warranty in a week so we'll soon see...
Old 08-11-2005, 11:33 PM
miljnor's Avatar
S.N.A.F.U.
I have an air dryer in my shop, and now that you mention it since we've gottin it there has been less tool sticking, but, it hasn't been eliminated completely. So, the problem probably is contaminantes in the taper if, having a dryer reduces the symptoms.
thanks
Michael T.
  #11   Ban this user!
Old 08-11-2005, 11:48 PM
Air dryer? Yes, definitely. We installed a refrigerated dryer a few years ago and that solved a lot of problems we had with both lathes and VMCs. We did have moisture traps but they just weren't good enough. Dry air solved all our problems except when we were doing heavy cuts as I mentioned earlier. I also checked with my guys; it is probably close to a year since the VF machine had a tool jam i.e since we put on the reserve tank.
  #12   Ban this user!
Old 08-13-2005, 04:41 AM
Burgs is on a distinguished road
We also experience this problem with our VF3 on heavy cuts. Lube and cleaning the taper helps, but I suspect the problem is the female taper expands and traps the tool under heavy load.
