Old 03-16-2011, 02:21 PM
behindpropeller is on a distinguished road
Solid Models of Machines?
Are there any solid models of machines out there?
Specifically a TM2.
Tim
Old 03-16-2011, 05:09 PM
WallyL7's Avatar
WallyL7 is on a distinguished road
No.
Tim
Old 03-16-2011, 07:52 PM
Gabe Newell is on a distinguished road
Models
I have had good luck asking tool makers for models (most recently Renishaw sent me a model for a probe). You might check with your HFO.
Are you needing this for CAM or floor lay-out or...? I needed a table lay-out and it only took a couple of minutes to make one off the drawings on the Haas' website.
Old 03-16-2011, 11:41 PM
Here's the TM1 drawing at Haas.
http://haasportal.net/Portals/57ad71...ne%20Views.pdf
Old 03-17-2011, 10:06 AM
WallyL7's Avatar
Gabe - what actual machine models have you gotten? I've tried to get them from my HFO, but they don't give them out.
I think it would be cool if they had a 3d model shell at least. It helps a lot when laying out a shop floor. I ended up using the overall dimensions they post and just modeling it myself. I like the idea of a modeled shop floor (3d) with actual 3d machines. Really gives you a good feel of how the flow will end up.
Tim
Old 03-17-2011, 10:39 AM
Yeah. I was just looking for a shell.
Tim
Old 03-18-2011, 12:50 PM
Ydna is on a distinguished road
I've made some random models for design/layout purposes, but most of the machines were VF's...don't have any for the TM mills....
Old 10-20-2011, 11:39 AM
daedalus0x1a4 is on a distinguished road
I hate to resurrect a dead thread but does anyone have VF-6 models floating around? Today I started at the spindle but there is a lot to do.
Old 10-20-2011, 12:45 PM
txcncman is on a distinguished road
Depending on how accurate you want your model to be, this might help your process out a little:
http://haasportal.net/Portals/57ad71...%20Views_A.pdf
http://www.kirkcon.com/
Editing Solid Models In Esprit thebowman Esprit 4 01-23-2011 06:19 PM
Need Help!- Aligning solid models cncstephen Mastercam 3 03-11-2010 01:58 AM
Fadal 15 solid models robyc01 Fadal 2 11-19-2009 09:18 AM
Looking for solid models of a couple of threadforms youngjim Mechanical Calculations/Engineering Design 3 09-20-2009 04:49 AM
Which came first, Solid Edge or Solid Works? Arnie General CAM Discussion 3 09-15-2004 06:25 AM
