| Has anyone extended the boom that holds the operators panel (Control panel) on a Hass TM-2 mill. It may be the same for a TM-1 I want to move it approximately 14 inches. Is there enough cable ? If not what did you do to make it work. Did you cut and splice the cable, or where able to make extension cables using conector without cutting the orginal cables. TAFC |
| Yes we have. Had to extend a couple wires, but the main cable was too short. Haas sold us a longer cable. Think it was for a vf5, was pretty cheap, I wanna say like two hundred bucks. I can try to find a part number on Monday. |
| I'm in the process of designing an enclosure for our TM-2. A sheet metal shop I work closely with will be doing the fab work. If you are interested feel free to drop me an email. I have seen the $5000 enclosure, and I'm pretty sure I can beat that price by a significant amount. Tim tim.cochrane@gmail.com |
| I did it. I have a TM-3. And 14" is exactly what I did. There's plenty of slack in the lines. I remade the arm, but I wasn't comfortable only using the existing 4 bolts to hold the extra weight/leverage, so I made a brace that holds the weight about 12" out from the bolt pattern...kinda between the panel and the bottom pan. I can take pics if you are interested. I used aluminum checker floor plate for the main enclosure...and I made clips that pinch it to the existing pan...not screwed. That way I can take it off quick if I need clearance. You need to make pockets in the sides of the enclosure that clear the table on the ends...your servo and hand-wheels actually overlap the bottom pan plane. I then made a roller system and used Lexan for the doors. Now, all the chips and coolant stay in the machine...and it only cost me about $1500 in material...the enclosed model was another $10k. I am attaching a crappy pic to show the gist of it. I am perfectly happy with mine. |
| Need Help!- Accessing Software Operator Panel Oi-TC | adamant | Fanuc | 15 | 02-26-2011 12:44 AM |
| Mazatrol T1 Operator Panel Problem | mattme | Mazak, Mitsubishi, Mazatrol | 8 | 04-25-2010 06:44 PM |
| FANUC OPERATOR PANEL A02B-0083-C160 CNC | pimpbike | EBAY ADS | 0 | 12-22-2009 05:17 PM |
| Relocate "mark forums read" | pminmo | Suggestions for the CNCzone.com site. | 1 | 02-18-2006 12:27 PM |
| CNC Operator Panel Design | Al_The_Man | DIY-CNC Router Table Machines | 17 | 09-13-2004 12:03 PM |
