Old 03-10-2011, 02:00 PM
Rainman863 is on a distinguished road
1997 Haas VF9 Y axis vibration
When feeding on the Y axis machine vibrates badly, I can't get a good finish. Also, I am informed it rarely needs way lube. What could be the cause of this?
Old 03-10-2011, 05:04 PM
WallyL7's Avatar
WallyL7 is on a distinguished road
Did this just start happening? If so, it is time to change the Y-axis servo motor. You should feel lucky if you are changing it for the first time on a 1997 machine.
It is pretty obvious on these machines when they start to go out. One axis cuts smooth like normal and the other isn't. They usually start getting worse and worse.
Pretty much that easy to tell. Could be something more odd than that, but I doubt it.
They don't go through an obnoxious amount of lube really. You can easily go a couple months without adding any on a lightly used machine. They are not "heavy oilers" by any means.
Good luck.
Tim
Old 03-24-2011, 08:04 PM
I've heard you can tune the amplifier boards to take the vibration out....has anyone heard of that? Also, Selway Machine in Hayward, Ca. has looked at it 3 times, and doesn't know what's wrong. Is there anyone else in the Bay Area qualified to fix Haas Mills?
Old 03-24-2011, 08:55 PM
Delw is on a distinguished road
the tach can give you vibration also, check the brush's in the motor to make sure they are good. if the brush are good there could be carbon build up on the comutator(sp) clean it with a pencil eraser.
Old 03-26-2011, 01:12 PM
Wizzard of H is on a distinguished road
Y axis vibration
It's not acceptable for a dealer to say "they don't know what's wrong and can't fix it."
Brush or brushless?
Brushless motors just don't wear out that way.
Brush motors could need new brushes.
Screw could be damaged and alternately binding.
Amplifier could have a problem (brushless only - brush would just stop).
Parameters could be "messed with" - make sure no changes.
Can't tune this out if it worked once and then started to shake
Lean on dealer and threaten to call Haas.
They WILL charge you BUT they WILL fix it.
Could swap amplifiers to see if problem moves - easy connectors.
Old 03-26-2011, 11:10 PM
hdcncservices is on a distinguished road
hey wizzard, you say that selway hfo been there 3 time, and can't fix the problem, when do your shop locate? cause i know this tech he is very good service tech, he is haas certified and he works on matsuura and other machine and he charge very good price, (hdcncservices@yahoo.com )
Old 03-27-2011, 08:33 PM
Pondo's Avatar
Pondo is on a distinguished road
This is for axis hum, usually at rest though:
There are 4 bit switches in the parameters for each axis that can be adjusted. They are Low pass 1X, low pass 2X, Dfilter X8, and Dfilter X4. Change them 1 at a time (either to a 0 or 1) and it will get rid of the humming. My mill had a similar issue in the Y and Z axis. Changing the parameters took care of it.
(Don't forget to change setting 7 to allow the parameter changes, plus it must be in E-Stop to change parameters)
Parameter 1=X axis
Parameter 15=Y axis
Parameter 29=Z axis
I do not know if it will help with your cutting problems. I had a VF-4 that was abused and would not cut in the Y+ direction without chattering no matter what we did.
Hope it helps
Apparently I don't know anything, so please verify my suggestions with my wife.
Mazak lathe 7 axis Integrex 200 1997 Aaron 1874 Mazak, Mitsubishi, Mazatrol 0 04-03-2010 08:09 PM
Need Help!- processor for 1997 Kitamura Mycenter 1 W/4th axis Pmp Audio Post Processor Files 0 12-16-2008 05:48 AM
In 'X Axis' Having vibration dspjbp Machine Problems, Solutions , Wireless DNC, serial port 0 12-20-2007 12:27 PM
cause of Z axis vibration dahui Shopmaster/Shoptask 5 08-16-2007 09:39 PM
X axis vibration harvard5 Servo Motors and Drives 1 08-14-2007 08:07 PM
