Old 03-10-2011, 10:01 AM
1000F is on a distinguished road
VF-4 Spindle Drive Alarm
Everybody has been scratching there head about this one.....
I have a 1995 VF-4, with a 10K spindle and a mitsubishi spindle drive. This machine is in very good condition, having never been in a manufacturing environment.
After pulling a piece out of the vise and causing a noise in the transmission-I had Haas come out to repair the machine. They installed a new motor, transmission and 10k spindle.
After the repair I started getting alarm code 123 (spindle drive alarm) at around the 700 rpm range. The fault code on the drive unit is E.0C2 (overcurrent shut off-constant speed).
The Haas techs have been here six times now just for the new alarm-with no success. Any ideas about would be greatly apprciated. Thanks.
Old 03-10-2011, 10:10 AM
Wizzard of H is on a distinguished road
Drive alarms
If the original service did not change the drive, there's no reason to suspect it.
That message (EOC) is overcurrent.
It can be caused by a short in the motor or the wiring to it.
You should check the load meter readings thru the range of spindle speeds.
It should be less than 25% when it gets up to speed - at all speeds.
Anything else suggests the wrong motor, wrong motor winding, or drive parameter error.
Old 03-10-2011, 12:00 PM
haastec is on a distinguished road
Have them park their @$$ there until they get it figured out and adjust their time accordingly. Most likely they did something wrong during the replacement or have bad parts.
Old 03-10-2011, 12:05 PM
Thanks for the post.
I should add that the spindle load meter is all over the place at different RPM's. And, rarely below 50%.
Old 03-11-2011, 12:11 PM
Bryan33 is on a distinguished road
change par 150 to 2500
Old 03-11-2011, 12:13 PM
try changing parameter 150 to 2500
Old 03-11-2011, 12:18 PM
parameter 150
You should NOT change parameter 150.
This is non-vector-drive machine.
It uses an open-loop variable speed drive.
That parameter is how the control knows the ratio between high and low gear.
Many things will stop working properly if you have anything besides the standard shipped value there.
Old 03-11-2011, 01:29 PM
Well it appears that they finally have it fixed....the motor was wired incorrectly. Thanks again for all of the post.
1992 VF2 Alarm 123 spindle Spindle Drive Fault dafowfidy Haas Mills 15 05-14-2012 01:32 PM
SL-1A spindle drive alarm nlh Mori lathes 4 06-28-2010 04:10 PM
Help with spindle drive alarm alphaorange Hardinge Lathes 3 05-15-2009 07:54 PM
Spindle drive alarm in fanuc 16 ta miguisu Fanuc 3 02-20-2007 10:12 AM
Spindle Drive Alarm AL-03?? msmart Fanuc 2 11-25-2006 10:27 PM
