Old 03-09-2011, 02:14 PM
1983CRAZYBB is on a distinguished road
Change parameter
tried to change 76 low air pressure got a servos on alarm and won't allow me to change.
Old 03-09-2011, 03:04 PM
ToyMaker94566 is on a distinguished road
So is your air pressure low then...?
Old 03-09-2011, 03:11 PM
Machineit's Avatar
Machineit is on a distinguished road
Just hit emergency stop. You need to turn the servos off to change parameters.
Mike
Haas VF-2, HA5C, BobCAD V23
Old 03-10-2011, 08:28 AM
Setting 7 has to be OFF and E-Stop pushed.
Old 03-10-2011, 10:06 AM
Wizzard of H is on a distinguished road
low air
Beware...
Changing parameter 76 to a larger number won't fix the low air.
It will just keep the control from telling you that you have low air.
If the guage says pressure is below 85 PSI, adjust it or get a better supply.
If the guage is correct and get low air, the sensor is the cause.
Need Help!- haas parameter change 1983CRAZYBB Fanuc 1 03-09-2011 06:13 PM
Need Help!- Change parameter 5101 jdgromi Fanuc 2 04-03-2009 06:57 PM
Using G10 L50 Parameter Change Command marcwdci Fanuc 12 07-23-2008 11:10 AM
Parameter change adamant Fanuc 1 05-28-2008 11:37 AM
Tool Change Parameter Jason812 Fanuc 3 11-20-2007 07:29 PM
