Hello, I am just getting started with g-code so bare with me. I have a Haas Mini Mill that we have been running an HRT-210 on with a external controller. The code for the indexer to move is an M21 command. Am upgrading to a VF-3 with 4th axis pre-wire, so I should be able to control the 4th directly from the code. Correct? Now, since I don't have the technical ability at this point to re-post the programs (we contract a guy to post the code for us) I was hoping I could just edit the M21 commands to A axis commands. So, as I understand it, N117 M21 (STEP 2 A0) would become N117 G90 G00 A0 M11 N118 M10 Also, do I need to specify the M11 & M10 commands or does the air brake automatically disengage and reengage when the A axis in put in motion? Thanks for the help with newbie stuff. |
| When you are using the rotary to make an indexing move it is nit necessary to unlock and relock the brake. When you are using the rotary in combination with the other axes to make an interpolated move you should unlock the brake a block ahead of the command for the interpolated move. The rotary will unlock automatically but that introduces a slight delay in the rotary motion compared to the other axis motion.
| Need Help!- FANUC 18T CONTROLLER G10 CODE | bkorte | General Metal Working Machines | 2 | 07-15-2010 09:47 AM |
| Newbie Question - How to get the code into the controller? | ktmrider | Fanuc | 6 | 12-17-2009 09:36 PM |
| Floppy drive enable code | thouse | Cincinnati CNC | 3 | 05-26-2009 11:52 PM |
| g code controller | Mut designer | Servo Motors and Drives | 10 | 11-24-2006 01:40 PM |
| Controller Code Snippets | jhwatts | OpenSource Software | 3 | 10-10-2005 11:07 AM |
