Old 02-23-2011, 07:25 PM
l u k e's Avatar
l u k e is on a distinguished road
Hard water and coolant question
We have fairly hard water locally should I be concerned about using it to mix with my coolant? Would it be worth while to filter the water first or am I over thinking it?
Old 02-23-2011, 07:50 PM
HuFlungDung's Avatar
Moderator
I like to use reverse osmosis purified water, as our local community water is also hard.
Since I might use the same batch of coolant for a year or more, and have to top it up fairly often (due to evaporation), I can only imagine that the coolant would otherwise get very much harder, quite quickly, as the mineral concentration would keep going up.
Old 02-23-2011, 08:54 PM
l u k e's Avatar
I dont have access to reverse osmosis water, I wonder if setting up a simple filter system would do me any good?
Old 02-23-2011, 09:28 PM
Karl_T's Avatar
Karl_T is on a distinguished road
I tried a batch of distilled water right after coolant change on my Hardinge lathe. It foamed up like a bubble bath, So, you can go too far also.
Old 02-23-2011, 09:45 PM
MadMax is on a distinguished road
Most filtration does little to remove dissolved mineral content. You could get a water distillation doodad though:
MIDI STILL SS-5 WATER DISTILLER FREE SHIP - eBay (item 250773944807 end time Mar-16-11 16:59:08 PDT)
This one processes 8ga per 24hr day which isn't too bad. How many machines do you need to make up water for? I find I go through 2-3ga for each of my machines per day.
Old 02-23-2011, 10:36 PM
Collect rainwater or get some 20l bottles of water for a water cooler and use that.
Old 02-23-2011, 10:47 PM
l u k e's Avatar
Originally Posted by Geof View Post
Collect rainwater
lol, I live in the Arizona desert. If I start now I might collect enough water in two years to get my 50 gal coolant tank filled up.
Old 02-23-2011, 10:50 PM
l u k e's Avatar
Is there any adverse affect to the machine itself using hard water or is it just a coolant issue?
Old 02-23-2011, 11:09 PM
As far as I know there are no adverse effects on the machine, it is just that heavily mineralized water does not mix with the coolant correctly.
I think you need to take my second suggestion, get water cooler bottles; this is probably less expensive than installing your own reverse osmosis system.
Old 02-24-2011, 08:58 AM
Moderator
It might be a minor issue, but hard water stains can appear on your parts unless you diligently dry them or rinse them immediately. Seems like a small issue until you have to resort to polishing them all up before you ship, then it's just a PITA and steals a few more minutes/hours from your life.
  #11   Ban this user!
Old 02-24-2011, 09:01 AM
Ydna is on a distinguished road
Would water extracted by a dehumidifier be comparable to this? Thats a water source we have in abundance here...
  #12   Ban this user!
Old 02-24-2011, 10:14 AM
Matt@RFR is on a distinguished road
Call your coolant manufacturer and see what they recommend. They are, after all, the experts. When I first got my mill, I got together with Blaser, who requested a tap water sample sent to them. Once they tested it, they recommended a coolant (and would have recommended corrective action with my tap water if I needed any), and I couldn't be happier with what I have.
I don't know what coolant everybody else is using, but after a lesson from Blaser about the coolant I'm using, extremely soft water is actually BAD, so all the talk about distilled water would not work for me. Point being, these guys are telling you what works for them, but there's been no mention of what coolant they are running and I have a hunch that that makes a world of difference.
How to control the water coolant by mach3? Mongkol General Metal Working Machines 2 11-17-2010 03:06 PM
Water based coolant - suppliers in Australia? LeonM Australia, New Zealand Club house 6 11-13-2008 03:51 PM
Water Based Coolant classictom General Metalwork Discussion 4 08-26-2008 06:04 PM
Coolant, mixing in more water smellyfeet General Metal Working Machines 7 06-30-2008 06:39 AM
Water-based coolant/lube use and handling jim_stoll Benchtop Machines 6 11-13-2007 12:49 AM
