Old 02-17-2011, 08:09 PM
buzzpettit is on a distinguished road
help with speeds
I am machining brass in a small haas that the max rpm is 4000. the carbide mill i want to use is .250 which it says to use a speed of 11000. Is it ok to run in my machine at the 4000 rpm or would it just be best to switch to some HSS cutters??
Old 02-17-2011, 08:18 PM
Matt@RFR is on a distinguished road
You could run that tool at 100 RPM*, it's just not going to work as well as 10,000 RPM.
*Not recommended.
aadrew10 is on a distinguished road
You can run carbide into brass at 4000 rpm. If I were you I would run HSS first, because I don't think you'll see any performance gain from carbide if your max rpm is 4000. Try both, see which one you like best.
Old 02-17-2011, 08:35 PM
thanks for the info... i know the brass is soft so usinG HSS is ok just. I just had a carbide cutter so i thought i would ask... thanks for the ideas guys
Old 02-17-2011, 08:42 PM
TRIMI's Avatar
TRIMI is on a distinguished road
I WILL DO IT 1200RPM F10.
Old 02-18-2011, 10:41 AM
gizmo_454 is on a distinguished road
Personally, I don't care if you only have a 2500 rpm spindle. I would pick the carbide mill in a heart beat. You can run that carbide mill all day long and at the end of the day, you wouldn't see any wear. The HSS mill on the other hand, while it sure won't be junk, it will have some wear which will degrade your surface finish somewhat. Brass is very abrasive.
Good luck and have fun!
Mike
speeds and feeds bdrmachine SolidCam 6 04-12-2008 08:15 AM
speeds and feeds stevieboy General Metalwork Discussion 2 03-09-2008 09:55 AM
Need some help with speeds & feeds ldkell_2000 General Metalwork Discussion 6 03-01-2008 10:35 AM
feeds and speeds porkchop21 Bridgeport and Hardinge Mills 2 08-30-2007 07:52 PM
Reasonable speeds for a cnc? Oce Linear and Rotary Motion 20 02-12-2007 02:30 PM
