Old 02-14-2011, 02:11 PM
Cknoble1 is on a distinguished road
Question Need help with air pressure issue
I got an alarm when I tried to home out the machine this morning. the machines a vf4. It is a
"120 Low Air Pressure"-- (Air dropped below 80 psi for a period defined by parameter 76. The low AIR PR alarm will appear on the screen as soon as the pressure has gets low and this alarm appears after some time has elapsed)
I have my compressor set at 100 psi and reads 100 psi
The regulator to the machine is also set to 85 psi and reads 85 psi.
The air is going to the machine, because I clear the alarm and hit tool release and it releases the air. So it must be a problem with the regulator itself.
Can I just change parameter 76? how can I get around this until I get a new sensor? Any help would be greatly appreciated.
P.s this is the first time it has happened.
Old 02-14-2011, 03:59 PM
Matt@RFR is on a distinguished road
You might try squirting some air tool oil in the air line going to the machine, then cycle the drawbar a bunch of times and see if that helps anything.
Old 02-15-2011, 06:04 AM
Maintexpert is on a distinguished road
You could change Parameter 76 to all 9 and it will run as normal.
sounds like you just have a pressure switch going out.
Old 02-16-2011, 12:19 PM
Wizzard of H is on a distinguished road
low air alarm
If you can clear the Low Air alarm, then it was only a short period of time when pressure was low. You need to find out why and when pressure is going low enough to trigger the alarm. If the alarm is still on the screen, it does not mean the pressure is still low. It could have happened long before. Don't start changing parts until you know more answers.
Old 03-02-2011, 06:02 AM
BigNizzy is on a distinguished road
Make sure the air hose to the machine is bigger than that in the machine, failing that replace the small diameter hose there are some that are stupidly small with bigger diameters. we found that you have small diameter pipes feeding larger diameter pipes causing a drop in pressure, especially when using the air hose on the machine.
Old 03-02-2011, 06:41 AM
mactec54 is on a distinguished road
Cknoble1
You need the air pressure set at 100psi minimum up to the machine regulator, check the spec on the machine requirement
85psi is to low
Mactec54
Old 03-02-2011, 11:35 AM
haastec is on a distinguished road
Yes, make sure that you are supplying enough air volume to the machine. 85 PSI at the machine is correct.
Do not bypass the system by setting the parameter to all nine's without knowing what the issue is as you may run the risk of damaging something.
Find out when and why the low air problem is occuring and fix it.
Post more details if you still need help.
Good luck.
Old 03-02-2011, 04:50 PM
haastec
Quote
The Haas spec is for a minimum of 100 PSI at the machine regulator on the back of the machine, Not 85 PSI being the supply to the back of the machine 85 PSI is way to low, the alarm comes on at 80 PSI
Mactec54
Old 03-02-2011, 05:47 PM
Machineit's Avatar
Machineit is on a distinguished road
You must remember that as soon as the valve is opened and air flows, there will be a drop in pressure.
The last shop I worked at plumbed the shop with plastic tubing that was approximately 5/16 ID. That was fine for all of those using an air nozzle to blow something off, but every time the newly installed Haas mills would change tools, we would get low air pressure alarms. Believe it or not it took me about 2 months to get them to change.
Air flowing through lines is just like any gas or liquid, there is friction to the flow and if you have 100 PSI at the compressor and run it through 100 feet of line, you will only get maybe 80 PSI out of the end of it at best.
Supply more and let the regulator control it. Use large lines whenever possible. I always plumb my shops with PVC of 1/2 inch or better.
Think of it like your water hose at your house. When you first open the spray nozzle it has a little bit more force than a split second or so later. That is friction at work. If you ran that same water through a hose that was 1000 feet long, you would get very little flow out of it at the end.
Cheers---Mike
Haas VF-2, HA5C, BobCAD V23
Old 03-02-2011, 07:13 PM
Originally Posted by Machineit View Post
...... I always plumb my shops with PVC of 1/2 inch or better......Cheers---Mike
I think you will find few people who think that is a good idea; the material choice, not the size.
  #11   Ban this user!
Old 03-03-2011, 06:46 AM
Originally Posted by mactec54 View Post
haastec
Quote
I think we are both correct but interpreting the OP a little differently from each other. Yes, 100 PSI of air supply to the machine. Machine regulator set to 85 PSI per manufacture spec. The alarm does come on at 80 PSI which is why air volume is just as important.
Some older machines can get by with 1/4" ID air line, some need 3/8", and others require 1/2" ID air line minimum to work properly.
  #12   Ban this user!
Old 03-03-2011, 06:59 AM
Machineit's Avatar
In case I was not clear, I don't run PVC to the machine itself. I run my main lines around the shop with it, with regular hose to the machines. It handles the volume of air needed.
Only been doing it that way for 20 years without an issue.
Cheers---Mike
Tags
air pressure, pressure guage, pressure sensor
Need Help!- Low Lube/Oil Pressure VF2 jstucken Haas Mills 10 10-27-2010 08:17 PM
Mazak Nexus 250 lathe, with hydrolic pressure issue FanucIssues Mazak, Mitsubishi, Mazatrol 3 05-31-2007 09:02 PM
Clamping Pressure Team Pierson Work Fixtures and Hold-Down Solutions 7 02-12-2007 01:08 PM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 03:19 PM
TSC pressure alarm (151) crayner Haas Mills 1 11-15-2005 10:45 PM
