Old 02-03-2011, 09:30 AM
dayton murdock is on a distinguished road
1990 VF-1 102 Alarm
Hi All
I just took delivery of a 1990 VF-1 and at power up I have a 102 alarm with a 161 alarm. Can it be fixed or should I get my money back
Old 02-03-2011, 10:51 AM
102 is Servos Off, you always get this on start up and you hit Reset and then Power Up/Restart to home the axes.
161 is X-Axis Drive Fault which can be cause by a short in the motor, or a short of one motor wire to ground, or running into a mechanical stop.
Did the X axis move at all?
If the answer is Yes then possibly it ran into a hard stop when it tried to home which suggests that the limit switch is stuck.
If the answer is No then it could be shorted wiring but that machine has brush type motors so it could be a short caused by a build up of carbon dust.
Either way you are going to have to start taking off covers to expose the limit switch and motor. Both the switch and dust build up causing a short are fairly simply to fix. A wiring short may also be easy, a true short in the motor means a new motor which starts running into more money.
Old 02-08-2011, 11:51 AM
Need X axis motor
Hi All
My technician just left and I need to buy a replacement X axis motor for my HAAS Vf-1
Do any of you have a source for a re-built or new?
Old 02-11-2011, 03:07 PM
Machineit's Avatar
Machineit is on a distinguished road
Originally Posted by dayton murdock View Post
Hi All
On eBay right now.
Reliance HAAS Servo Motor E728 - eBay (item 220738171028 end time Mar-13-11 10:20:02 PDT)
Mike
Haas VF-2, HA5C, BobCAD V23
Old 02-11-2011, 03:51 PM
Wizzard of H is on a distinguished road
Neds a new brush motor?
Be careful. Those motors were prone to brushes wearing out and to coolant getting in But rarely did that kill the motor. If you can dry it out, clean it out, and get new brushes, you can test if it turns by just applying a 12 volt battery (car) to it. What is more likely is the encoder. Buying a motor may not get you the encoder. If all else fails, Haas has both.
Old 02-28-2011, 10:14 AM
Smile Machine is UP and RUNNING
Thanks for the help
The X axis motor needed to be rebuilt. The zero return cable was replaced it worn thru in a few places and a parameter was change back to original; the last owner had change a Z axis parameter for some reason. Now everything functions.
Old 02-28-2011, 05:21 PM
Machineit's Avatar
Congrats!!!!
Mike
Old 03-02-2011, 10:55 AM
Haas RS232
Hi All
Is there any where I can buy a cable to connect to my laptop to my vf-1?
Then there is the software, I tried to down load from OneCNC and was unable to complete the registration process. What do you suggest for a commutation program?
Need Help!- 1990 Mazak LaserPath Turbo-X48 Mykal Ward Laser Engraving & Cutting Machines 4 04-22-2011 09:31 PM
1990 VF1 ranchak Haas Mills 3 01-31-2011 12:15 PM
Need Help!- 1990 Partner IV and Centurion IV Problem! Eliteauto Milltronics 3 09-04-2010 02:05 PM
Need Help!- 1990 VF-1 docs blewis999 Haas Mills 2 06-10-2008 11:29 AM
Info on Hurco 5PVK - 1990 mfr date? arpieb HURCO 0 01-11-2008 01:08 PM
