Old 01-31-2011, 07:03 AM
tayfunk is on a distinguished road
Spindle is driven via Haas Vector Drive 40/50 Hp
Dear Friends,
I have a problem on Haas Vector Drive 50/50 HP. The problem is, when the stop code is given, spindle is stopping without any problem up to 980 rpm. But over the 1000 rpm spindle stopping as if without brake and stopping the spindle is take a lot of time. Has any one encountered with the problem? Can anyone help me about the problem?
Thank you
http://www.edim.com.tr
Old 01-31-2011, 12:21 PM
Wizzard of H is on a distinguished road
Spindle coasts to a stop
Problems stopping from a higher speed are usually caused by a problem with the "regen load resistor". This is the box marked HOT at the top of the cabinet. If the spindle coasts to a stop there should also be an alarm that occurs at the same time. It might be "overvoltage". That would indicate that the regen load is simply disconnected or the electronics in the drive is not working. A smaller parameter value for spindle decleration (maybe half) would verify if there is just more energy going into the resister than it can handle. Still, replacement parts for drive and regen-load are available from your dealer.
Old 01-31-2011, 12:47 PM
Thank you Dear sir, I have also thought the REGEN rezistor. I have already checked The rezistor. The Rezistor is normal. Machine sometimes was giving "Overvoltage" error message but not continuously. Depend on your idea I will check 75N120 IGBT and its electronic control command on circuit board.
Thank you again.
With my best regards,
Tayfun Kusluoglu
Sharing my Haas vector drive schematics tayfunk Haas Mills 7 01-12-2012 02:35 PM
Problem- HAAS VF2 vector spindle drive crococh Haas Mills 7 04-02-2010 09:33 PM
Need Help!- haas vector drive 20/15 hp paul emblem Haas Mills 3 09-18-2008 05:44 AM
Haas Vector Drive 20/15 Need Help tecko Haas Mills 6 02-22-2007 08:17 PM
Haas Mill, Vector Drive DEAN Haas Mills 1 03-17-2005 04:05 PM
