Old 01-27-2011, 11:03 AM
Doubleddaved is on a distinguished road
Maintenance
I have a VF8/50 and a VF3/50YT.
Is the spindle a sealed unit and gets no maintenance on these machines? I found a dipstick on the side of the z axis head under a 6 bolted cover that I take is for the gearbox.
Fill is on the top,check is on the side and drain is on the bottom.(for gearbox)
The repair manual covers both lathes and mills and is confusing at times.
Dave
Old 02-03-2011, 03:44 PM
Bryan33 is on a distinguished road
The spindle gets an air oil mist to it. As long as you keep the oil in your lub tank clean you will be fine
ES-L8 Maintenance kkarasch Okuma 3 01-07-2011 04:29 AM
TC-22 Maintenance tpmx57 Bridgeport and Hardinge Mills 2 03-16-2009 08:21 PM
X3 Maintenance Thorpydo Benchtop Machines 2 11-24-2008 09:48 PM
Die maintenance ??? dpotts Casting Metals 0 03-31-2007 03:53 PM
CNC Maintenance shinerbttu Employment Opportunity 0 05-17-2006 10:50 AM
