Old 01-20-2011, 08:34 PM
Brendan is on a distinguished road
way oil overflow?
Hi
I have a 2001 Haas VFO and I am getting a lot of coolant in the way oil overflow tank, in 25 running hours it may fill this tank up with 90% coolant.
Any ideas were to start looking, cover seals?
Thanks!
Brendan
Old 01-20-2011, 09:34 PM
The rectangular thing that the waste way oil comes out of is supposed to be a separator that sends coolant down a pipe to the tank and just puts way oil in the waste oil bottle. It gets gummed up with sludge and doesn't work so you finish up with coolant coming out of the oil pipe. Take it off, it is fastened on with a connector something like a hose fitting at the back, take it apart and clean it.
Here read this thread:
http://www.cnczone.com/forums/haas_m...ainer_vf3.html
Old 01-20-2011, 10:11 PM
Thanks Geof!
You guy's are the the best!
Need Help!- buffer overflow wildhorsemfg Fanuc 4 09-19-2010 03:45 AM
Need Help!- Buffer overflow OKUMAN Okuma 3 02-08-2010 02:53 AM
EZ-Trak Y DAC Overflow TRAK-Man Bridgeport and Hardinge Mills 10 12-16-2009 04:39 PM
EZ trak Y DAC overflow justartingout Bridgeport and Hardinge Mills 14 05-25-2009 11:31 AM
Fanuc 11m overflow Nandop Fanuc 4 03-05-2007 01:11 PM
