Old 01-12-2011, 02:21 PM
rabishop is on a distinguished road
Question Haas VF6 Z axis drops .025" during cuts.
We have a Haas VF6 that drops .025" in the Z axis during cutting without a change in the Z position shown on the control. Once the Z axis drops that
.025" it doesn't change any more.
Old 01-12-2011, 03:17 PM
ToyMaker94566 is on a distinguished road
If you're certain you're not sucking a cutter, it sounds like your Z axis motor is failing. I had a similar problem a few years ago with my VF3. The service tech put a new motor in and that was that.
Oh and a $1200 bill later...
Old 01-12-2011, 04:14 PM
cncserveng is on a distinguished road
Check the belt if it has one, for tension and condition. Check there is any wear in the pulley or coupling.
Is the axis brake sticking on ? it could be holding the axis until it releases (check the brake relay is good).
Check the feedback unit (encoder) on the motor or end of ballscrew connections are tight. Make sure the motor and the ballscrew nut screws are tight. Check the counterbalance weight (or Cylinder) system is ok (free and working).
Finally, measure the axis for backlash. In handwheel, in 0.001" pulses, how many clicks do you need in either direction till it moves ?.
If the mechanical checks are all ok, the problem then has to be electronic, possible fault with axis encoder or axis board.
Newbie- "Cheap" CNC Mill that cuts steel? parcheezy Open Source CNC Machine Designs 11 09-02-2010 12:23 PM
Need Help!- Thread Milling using "C" axis no "Y" on the machine tejano4life72 Mori lathes 7 07-19-2010 02:59 PM
Cutting 1/4" acrylic - perfectly perpendicular cuts possible? jeanyes Laser Engraving & Cutting Machines 3 04-29-2009 05:53 AM
Need Help!- Axis feed rate drops to zero then back to normal TurboBlazerX Fadal 8 03-20-2009 08:52 AM
Looking for 24" of Acetal/Delrin (or drops) - Suggestions? scorpion Glass, Plastic and Stone 1 02-25-2009 03:58 PM
