Old 12-28-2010, 12:29 PM
plastibob is on a distinguished road
shortcut for setting X & Y without math
Somebody has posted before, not sure if it was this forum a way to pick up the edges and set your Y and X axis to zero without dividing by two after you find the distance. Anybody know the short cut? Thank you.
Old 12-29-2010, 09:08 AM
Machineit's Avatar
Machineit is on a distinguished road
You didn't say what you are using for the edge finder, but it is obviously not the renishaw probe system.
I have used a basic .200" tip diameter edge finder for years. When using it I have a simple procedure for setting edges that I use and teach to others, little no math required.
When touch off an edge, X or Y, I just move the tip to the edge in the .001" setting jog and when I touch the edge I just switch to the Z axis jog to move up and when I move it up to clear the part I stop on the "O" (zero) point on the jog handle. Then you just go back to the axis you are setting and turn one full revolution more. That will be .100", or the center of the .200" diameter tip. That means that this is your setting for that axis.
It becomes easier as you do it more. You get to the point where you can almost stop at Z zero without even looking. Just crank the tip up until clear and stop with the little knob on the jog handle at the bottom and verify it is at zero. Move over the .100" and set that axis.
After setting that axis you don't need to hit jog again, just leave it on the offset page. You just hit the X, Y, or Z again and continue to set the next edge, as you will still be in jog mode even though you are on the offset page.
I can do a simple X Y edge find in about 20 to 30 seconds.
Holes are different, but you can reduce the complexity of the math easily. When you probe a hole, just move the tip into the hole at approximately the center. Start by setting the Y axis, as the human eye will locate the center of X better than Y, so start there.
Next touch the tip on the front or back side. Go to the position screen and go to the operator page. When in position just hit origin and the reading will be set to zero. Move the tip to the other edge and the readout will have the diameter of the hole minus .200 tip diameter. For example, if you are probing a 1" diameter hole, the readout will be .800". Whatever the number is, just divide by two and move the tip to the center or .400" in this case.
You do the X axis next and you are set to go to the offset page and enter both X & Y at once.
It takes only about 30 seconds and instead of say taking X-16.6763 and subtracting X-15.6763 then dividing by two and then adding that number to the smaller of the two and entering that number by hand, you just have to divide the difference of the reading, ie .800'' by two and move to that position and you are in the center.
You can do both X and Y very quickly, about 30 seconds depending on the size of the hole.
Still requires some math, but much easier math and usually simple enough to do easily in your head.
It is much more difficult to explain than to do, believe me.
Mike
Haas VF-2, HA5C, BobCAD V23
Old 12-29-2010, 11:47 AM
Thank you for that good information, however I wasn't quite explicit enough. I'm trying to find the center using and edge finder. What I typically do is pick up one edge, set zero, move over to the opposite edge and then divide that number by two. There was a shortcut that takes out the math of dividing by two. That is what I'm looking for.
Old 12-29-2010, 11:48 AM
littlerob's Avatar
littlerob is on a distinguished road
Umm, there will be dividing by two required at some point. Whether it's the edge finder, or the part or both, or the probe or the gage pin or whatever, there will be dividing by two required. I haven't used the renishaw probe but I'm guessing that even in the program you will have to divide by two. If dividing by two is a problem we should start there, me thinks.
Robert
The beaten path, is exclusively for beaten men.
Old 12-29-2010, 12:57 PM
math is not the problem, it's the potential for error. I found what I was looking for in this post:
http://www.cnczone.com/forums/769038-post4.html
Old 01-01-2011, 03:26 PM
You are still dividng by two, but doing it using a procedure that is probably as close to error free as anything can be.
Old 01-01-2011, 04:15 PM
littlerob's Avatar
Build Thread- Was going to build, but took a MAJOR shortcut instead! panozeng Plasma, EDM and other similar machine Project Log 6 12-21-2010 11:13 AM
Flashcut CNC Ver. 3 : Keyboard Hotkey/Shortcut Reference bexprecision FlashCut CNC 2 05-19-2010 09:52 PM
Need Help!- Gibbs shortcut key crash!! btdmfg GibbsCAM 1 06-29-2009 09:47 PM
shortcut to Mcam x nc editor? panaceabea Mastercam 2 01-27-2009 08:39 PM
Is there a shortcut for this??? jsnbrgg Rhino 3D 5 04-02-2007 03:10 PM
