Old 12-13-2010, 02:10 PM
Cheshire is on a distinguished road
Alarm 527 = NOT EXPECTED OR THEN REQUIRED
I am getting this alarm on my HAAS
527 = NOT EXPECTED OR THEN REQUIRED - Only one assignment is allowed per block, or a THEN statement is missing. Check macro formatting.
I can't figure it out but I am new to programming macros
O9900
N010 [#7 = #7 - .1 ]
N015 [#37 = ABS[#26]+ABS[#7]]
N020 [#34 = 1+FIX[#6 * #37]]
N025 [#35 = #23/2]
N030 [#36 = #25 + #35]
N050 [#43 = #7]
N055 [#44 = 1 / #6]
N060 [#45 = #44 * .25]
N070 G40
N075 G90 G00 X#24 Y#25
N080 G43 H#19 Z#7 M08
N084 [#47 = #35 - #20]
N085 G91 G01 Y#47 F#9
N086 G41 D#19 X#20
N095 G03 X-#20 Y#20 Z#45 R#20 F#9
N100 G03 J-#35 Z#44 L#34
N130 G03 X#20 Y-#20 Z#45 R#20 F#9
N135 G90 G40 G00 X#24
N140 Z#26 M09
N145 M99
Any help would be great.
Thank you
-Dru "Cheshire"
Old 12-15-2010, 12:45 AM
JasonR is on a distinguished road
Are you sure you have macros enabled on your machine?
Old 12-16-2010, 12:40 PM
DruMor is on a distinguished road
Try it with the brackets removed from the start and end of each expression.
Where you have:
N010 [#7=#7-.1]
Change it to
N010 #7=#7-.1
I think that should get you going.
Optical switch, on when I expected off will gilmore General Electronics Discussion 9 04-23-2010 01:49 PM
First PCB, better than I expected astropor PCB milling 16 12-27-2009 11:02 AM
calculating expected max cutting force required eloid DIY-CNC Router Table Machines 9 11-01-2007 06:19 PM
Expected IPM drafterman Open Source CNC Machine Designs 7 08-19-2007 07:21 PM
Taig expected accuracy Moesian Taig Mills & Lathes 3 08-07-2006 11:58 AM
