I have a job I am doing and the part needs to be internally broached T60 I am interested in rotary broaching the parts in my machine I found a company that makes torx rotary broaches and when I was speaking to the salesman he thought that I might have trouble overloading my servos I found this unlikely but I have no experience with this at all so here it is Haas VF3SS T60 rotary broach 303 Stainless Steel part Thanks in advance |
| Max thrust for Z axis is 3923 lb, maybe compare that to a Lathe z axis thrust that is known to work with the broach. Andrew.
__________________ VF3+TRT210, VF3, VF2+HRT160, VF2SS+TR160, VF2SS+TR160, VF5TR, VF5TR, VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS |
| There is some side loading that goes on, but I dont think it will be a problem to you. the z-axis load is easily controlled by feed rate. How hard is the stainless? high speed steel is usually used for rotary broaches, and is about 47C. There are some carbide tipped broaches, but chipping is the real problem there. Your stainless will like to see a 3 degree hook min, and make the bore is as large as possible. If you are going to a shoulder or blind hole, do the broach in steps, for deeper holes, with chip clearing in between. and make sure you follow with an e.m to remove the last burrs. I have broached alot of aerospace parts for rosan ports. usually in 15-5 stainless. Currently working on Hy-Tuff which is the same hardness as the broach. thinking we may have to edm our own broach out of 300 m and take it to about 60C. good luck. |
| Well the thru hole makes it alot easier, and it's a torx shape, so there isn't a big load on the broach either. a search on the net will turn up different sources, Polygon solutions would be a good place to start. They have off the shelf broaches, and can do customs if necessary. |
#10
| Slater Tools is the company I use for this type of work. They have a tool-holding system that reduces the load. Another solution is two broaches (rough/finish).
__________________ Thanks, Ken Foulks |
#11
| Thank you for the tip I will get in touch with them Have you done any projects similar to this ? If so can you give me an idea of how many parts I could get out of a setup like this I know that there are a ton of variables but a rough guess would be appreciated |
| Online Rotary Broaching Video | peter@slater | Product Announcements & Manufacturer News | 6 | 01-04-2012 11:24 PM |
| Rotary Broaching | rhino | General Metalwork Discussion | 10 | 09-16-2011 01:15 PM |
| Need Help!- rotary broaching swiss | elsanch | General Metalwork Discussion | 4 | 01-06-2011 12:40 PM |
| Rotary Broaching Chip Accumulation | peter@slater | Videos | 2 | 06-25-2009 07:35 AM |
| Rotary Broaching Tool Holder Set-Up Video | peter@slater | Product Announcements & Manufacturer News | 0 | 10-07-2008 12:18 PM |
