| Check it out for your self: The Y travel is 12 inches. Measure the distance inside the MiniMill enclosure from the inside of the door to the Z way covers at the back; this is measurement M. Measure the overall length of the vise from the end of the screw to the back end of the moving jaw when the vise is fully open; this is measurement V. If M minus V is smaller than 12 inches you cannot mount the vise without it hitting either the door when the machine is at Y0. or the way covers when it is at Y-12.0. If M minus V is larger than 12 inches you are okay. However, if M minus V is something like 10 or 11 inches and you are machining small parts it may be possible to mount the 4" doublelock and use it safely by reducing the maximum Y travel to 10 inches. This will only work if you still have enough travel to reach all around your parts.
A Kurt Double Lock will fit on the Mini Mill. It leaves you about 3" between the hex nut on the vise and the sheet metal when Y is home. |
I don't have dimensions on the handles, but I can't imagine the handle sticks out more than a couple inches, so best guess is yes, you can leave the handles on and still clear the sheet metal. |
| Problem- Best way to mount 1/16 inch ball mill with 3/16 inch shank in router. | cjjonesarmory | Wood Working Tooling | 10 | 07-02-2009 05:38 AM |
| double vises usa or taiwan | BAD DOG | CNC Machining Centers | 5 | 02-11-2009 03:18 PM |
| x2 mill z axel wont lock? | brendan_h | Benchtop Machines | 4 | 12-19-2008 07:54 AM |
| Running carbide end mills in side-lock end mill holders | Cory | General Metalwork Discussion | 41 | 01-14-2008 07:55 AM |
| programming multiple double vises | bink | G-Code Programing | 12 | 10-26-2006 09:07 PM |
