Received the converter today, it took only 4 days from the time of shipping to get here in Ohio from India. It was packed well with no visible damage. Purchased from Kwality Enterprises 80, Queen's Road Near Hotel Suncity Towers, Amritsar (Punjab,India).143001 Ph: 0183-2224554, Fax:0183-5005595 (m): +919780485865 Vishal Chohan vishal@keindia.com Install was pretty straight forward, the unit replaces the 3.5" drive. There was a little pin confusion shown in the photo. Vishal's solution was to just press the ribbon cable a bit harder and it will unblock that pin, which it did. Formatting of the flash drive was pretty straight forward as well, the usual issues of not really knowing what was expected but all went well on this and the install after just a couple inquireing email, all answered promptly. Each flash drive is formatted into the equivalent of 100 3.5" Floppies. These 100 (0-99) blocks of floppy equivalents can be accessed from the converter at the control. To save files to these block from the PC requires a separate program that is included with the converter purchase, this software also formats the Flash drive. True, an extra step is required to save data on each individual block from your PC, but it is quick and uncomplicated. You have the equivalent of 100 floppies on the flash drive (a 4gb is recommended) so you must remember on what block your CNC Post is on. So now, hopefully, all those many trips back to the PC to reload the post onto yet another floppy will be a thing of the past. It worked well on first use, time will tell on the full scope of it's use and reliability. Now, what to do with 4 cases of floppies ![]() Ken |
| Many controls that used the old 3.5" have 1mb, and much less on even older machines, my Haas TM-1 has 1mb so it is a good match for these machines. This was designed as an alternative to the generally unreliable floppies and so far seems to do a great job If one was able to drip feed from the USB, now that would sure be nice. |
| Doesn't seem likely, as the control still is expecting to be reading a 1.44mb floppy. If you have post on say block 00 and 99 then you would have to be sure the converter is showing which one you want to read from, or save two. That is what the two numbers indicate, you go up or down in blocks by pushing one of two buttons. EDIT: This is not a converter short coming, it is the way the control or PC is requiring. |
If you have a program that is larger than 1 floppy, you could connect the RS232 port to a PC. The cable is cheap, especially if you make your own, and DNC software is free for download on the web. |
| I would like to see a simple floppy converted into a usb reader should be simple and cost effective.... but I have not found anything of the sort
__________________ individual who perceives a solution and is willing to take command. Very often, that individual is crazy. |
| Check out this other thread: http://www.cnczone.com/forums/haas_m..._machines.html
__________________ Thanks, Ken Foulks |
| Just IN- 31/2 floppy converter for many cnc machines | plrelectronic | Product Announcements & Manufacturer News | 0 | 10-28-2010 12:00 PM |
| 3.5 floppy | Delvis | Fadal | 4 | 03-27-2010 12:02 AM |
| floppy to usb, crt, pendant | Cartel, LLC | Haas Mills | 6 | 03-19-2010 03:12 AM |
| Need Help!- DNC from floppy drive | jwknow | Haas Mills | 5 | 03-11-2010 08:39 AM |
| Floppy Drive | advt001 | Cincinnati CNC | 4 | 10-11-2008 09:35 PM |
