We are running a tm-1, vf2, vf4, vf6, and ec400pp using TiN coated carbide tooling with 100 sf/m and .001 chip load per tooth. I am new to machining and have only been doing it for a year. The material we are using is 1045 hot roll steal. Cutting at a dept of up to 1.25. The problem we are having is tool breakage and wear. I should also add most cuts are made threw the center area of the work piece with little room for chip clearance. We tried multiple passes at a depth of .2 but they are complaining about long run times which are up to 6 hrs in some cases. Any advise i could get would be great thanks. |
| You are running your endmill too slow. That is why it is breaking. 300-350 SFM in hot roll steel with a carbide 4 flute TIN coated E/M. Also,drill a pilot hole for the E/M to Z down. Example: 1/2 E/M @ 300 SFM .001 per tooth: Spindle speed: 2,292. Feed: 9 IPM. Hope this helps you-Dan PS: The SFM you are running is for HSS. Many CAM programs default to HSS feeds and speeds. |
| Buy and download Gwizard GWizard: A CNC Machinist's Calculator The only values I struggle with using this software is the feed rate in 300 series SS using a cobalt drill. All other values and optimization tools work excellent
__________________ www.machmachine.com |
| It depends on a lot of variables. Ridigity of the machine Ridigity of the workpiece Ridigity of the tool + toolholder Coolant or not Air blast or not A baseline to start from for carbide in 1045 HRS would be about 225 SFM and .002/tooth chipload. With air, no coolant. Up to 1X dia DOC. Ask your tool distributor for the cutter Mfg's recommendations. They vary a lot. For lower DOC, you can go a bit higher on the SFM and a lot higher with the chipload. Coolant has it's pluses and minuses. I do not use it on steel for any milling because of the thermal shock giving poor tool life, but some people swear by it. Again, ask the tool manufacturer.
__________________ Apparently I don't know anything, so please verify my suggestions with my wife. |
| C1045 is fairly machinable stuff, I'd be pushing 300 to 400 SFM, and slow down for the tougher stuff like 4140 prehardened ![]() If I understood the original post correctly, it sounds as though deep slotting operations are being performed with a tool as wide as the slot. It may prove worthwhile to investigate a high speed machining strategy, permitting deeper DOC, smaller tool, permitting some tool movement within the slot, and better chip removal, more use of the total flute length of the tool, etc. Plowing full width making deep slots is old school.
| We are using Tin coated carbide 4 flute sizes from .25-.75 tooling. I am thinking of trying to get them to let us try more passes at .02 DoC with the feeds and speeds in the Machinery's handbook. Last edited by Tirena; 12-06-2010 at 02:43 PM. |
| Cutting Speed of Metals Values for High Speed Cutters in Feet/Minute Multiply x3 for Carbide Aluminum All alloys 250 and up Soft Brass Half hard 150-220 Hard Brass and bronze Full hard 60-160 Cast Iron All 60-100 Mild Steels 1018, Free machining stainless 80-120 Tough Steels 304 Stainless, Tool steels 40-80 Good Luck~! Go here this might be useful to you. Milling Speed and Feed Calculator |
#10
| I cannot say it enough. Talk to the manufacturer of the tool. Machinery's Handbook is giving starting points and, from my experience with it in today's day in age, is not very accurate for most CNC stuff today. It is all dependent on HP, rigidity, and the tool manufacturer's recommended feed and speed. Every type and size of end mill will be different to some degree. But even then, there still is some wiggle room for adjusting. For roughing purposes, depending on the size of the slots you are milling, you might want to look into a high feed cutter. Several companies make them. I like Mitsubishi's AJX cutter. I only have a Mini Mill, but I can run their 3/4", 3FL at 0.03" DOC, 1/2" width of cut, 0.016" IPT, and 330 SF/M in medium carbon steel all day with no problems. That is very conservative for what the end mill is capable of in a more powerful machine. Good luck! Mike |
| Series II spindle speed accuracy? (trouble with upgrade) | dkochan | Tormach PCNC | 3 | 11-09-2009 06:10 PM |
| Need Help!- Trouble With Aluminium Feed | Brenck | General Metalwork Discussion | 6 | 04-04-2009 03:48 PM |
| Speed and Feed | kdoney | Benchtop Machines | 26 | 03-30-2006 05:21 PM |
| Speed and feed... | kombayotch | General Metalwork Discussion | 13 | 03-07-2006 07:12 AM |
| speed and feed | KBW | General CAM Discussion | 2 | 02-20-2004 09:18 PM |
