Old 12-02-2010, 12:41 PM
dahui's Avatar
dahui is on a distinguished road
warmup program: dwell time is incorrect if set > 60 seconds
Hey all,
My warmup program (VF1) specifies a dwell of 300. seconds per RPM setting, but it only runs for about 45 seconds. I played around with a bunch of values. Any value less than 60. produces the correct dwell time. However, anything above 60. produces an apparently random dwell time...but always less than 60 seconds. Thoughts?
Oh and my program is identical to my neighbor's VF3, which works fine.
Old 12-02-2010, 12:45 PM
dcoupar's Avatar
Are you always specifying P with a decimal point? With a decimal point, P is seconds, without a decimal point, it's milliseconds.
Old 12-02-2010, 12:48 PM
dahui's Avatar
Yes,
S500 M03 P300.;
Old 12-02-2010, 02:43 PM
JohnJW is on a distinguished road
I think you have to add a G04 for the dwell command followed by the P command for the length time.
On the default warm up program it's something like
S500 M3;
G04 P1000.;
. . . once I forgot the decimal point and had a pretty good scare when the rpm suddenly ramped up when I wasn't expecting it. . .
Old 12-02-2010, 02:52 PM
beege's Avatar
beege is on a distinguished road
Not familiar with Haas. I do know on some machines, if you're in IPR, then dwell is in revolutions, not seconds or milliseconds, and if you're in IPM, then it's seconds
Old 12-02-2010, 02:56 PM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
Yes... I have to Input a G04 and a decimal point after the dwell amount to get my Hass to do right.
Old 12-02-2010, 03:14 PM
dahui's Avatar
Sorry I misstyped I have: S500 M03 G04 P300. I don't think it's ipr because if I input P60. It runs for 60 seconds but if I input P70. It runs for about 12 seconds.
Old 12-02-2010, 03:15 PM
KenFoulks's Avatar
KenFoulks is on a distinguished road
Earlier Haas software versions had a problem when dwelling over 60 seconds. To overcome this, order a new machine..... Or, you can program a 300 second dwell using multiple lines; like this:
G04 P60.
G04 P60.
G04 P60.
G04 P60.
G04 P60.
Thanks,
Ken Foulks
Old 12-02-2010, 03:30 PM
dahui's Avatar
Okay, just tried a test and here are the results:
P30. = 30 sec
P60. = 60 sec
P100. = 34 sec
P300. = 37 sec
Mysterious for sure.
Old 12-02-2010, 04:01 PM
KenFoulks's Avatar
What software version do you have, if you have 3 or above, it can be fixed with a software update.
(Fixed in SW version 3.16)
Thanks,
Ken Foulks
  #11   Ban this user!
Old 12-02-2010, 05:50 PM
dahui's Avatar
I have version 3.9
  #12   Ban this user!
Old 12-02-2010, 08:09 PM
KenFoulks's Avatar
You can upgrade by contacting your HFO, they will replace the processor.
Thanks,
Ken Foulks
Need Help!- fanuc 10m dwell time skippyfix Fanuc 19 09-03-2011 10:25 AM
Mach3 Compatible Axis Warmup Program Phife Mach Software (ArtSoft software) 1 01-15-2010 09:39 PM
Warmup Program Gcode Phife DIY-CNC Router Table Machines 6 01-08-2010 07:45 PM
Dwell time GBRAVO I.C. Engines 5 06-10-2009 02:19 AM
cycle time macro program mcash3000 General CNC (Mill and Lathe) Control Software (NC) 1 03-29-2006 12:33 PM
