Old 11-25-2010, 05:36 AM
rusty1979 is on a distinguished road
variables when probing on haas super mini mill
can anyone please tell me what variable is set to the Y axis when probing a single face on a haas super mini mill. So far Haas have been no help and renishaw have helped as far as they can go, so if you have any ideas then please submit them thanking you in advance.
The prog is as follows
G90 G00 G40 G80 G98 G17 G21
N1G90 G00 M09
G53 Z0 M05
M01
T10 M06
G90 G00 G55 X0 Y6.
G43 Z5. H10 D10
G65 P9023 A9. S55.
G00 G90 Z5.
X0 Y0
G01 Z-1.5 F1000.
G65 P9023 A1. D6.488 S55
G00 90 Z5.
X-5.5 Y0
G01 Z-1.5 F1000.
G65 P9023 A7. YT4.125
#600=#136
G00 G91 X11.
G65 P9023 A7. Y4.125
#601=#136
#602=[#600+#601]/2
G68 G90 Y0 R#144
G90 G00 M09
G53 Z0 M05
G53 Y0
M30
Old 11-25-2010, 07:01 PM
omy005 is on a distinguished road
Can you give us some more information in regards to what you are trying to do? Work out the angle for co-ordinate rotation after probing?
I can see a problem in the line below highlighted with bold.
Andrew
VF3+TRT210, VF3, VF2+HRT160, VF2SS+TR160, VF2SS+TR160, VF5TR, VF5TR, VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS,VF2SS+HRT-210HSHS
Old 11-26-2010, 01:48 AM
sorry there is a type error in there the "t" is not ment to be there
we are trying to realign a slot on barrell to re machine the slots that are slightly off centre rather than clocking the slot faces as we have many to do then rotate the "y" axis to realign the slot using the g68 R but we do not know what variable it should be righting it to and haas Uk do not also know you can imagine looking thorugh all the variables trying to find which one it is righting to
Old 11-30-2010, 12:22 PM
guypb is on a distinguished road
9023 A7 Yyy is Easyset speak for Inspection Plus cycle 9811 Yy.
#136 is standard Inspection Plus mesasured Y value BUT, if you have the WIPS option installed the variable will most likely be shifted forward by 50 - so #186.
I've IMed you - please contact me if you want to know more - this is my speciality.
renishaw probing on haas mini mill kwhite2 Haas Mills 1 09-30-2010 04:51 PM
Haas Super Mini-Mill and Haas Trunnion Table Gabe Newell Haas Mills 6 06-07-2009 01:23 PM
HELP!! Haas Super Mini Mill CountBraden Haas Mills 4 07-06-2008 06:20 PM
HAAS Super Mini Mill Ford25 Haas Mills 13 09-07-2007 08:01 AM
Engraving on an Arc using Haas Super Mini MIll chop5280 Haas Mills 10 04-10-2006 06:42 PM
