Does your TM-1 have a USB Drive?
If so, I think you can run the programs directly from the USB Drive instead of the internal machine memory. I also believe that when this is done there are certain limitations which others here can explain.
The size of the USB stick would be your only limitation.
John
LinkBack URL
About LinkBacks
