Old 11-23-2010, 06:02 PM
riverracer is on a distinguished road
tm2 lockout
is it possible to place a password on a late 2007 controler to stop unauthorised use?
we could place a padlock on the master switch, but are not allowed too.
something in the startup sequence would be the way to go.
have come into work last couple of days and someone on the other shift has been trying to access / use the machine.
no damage done yet, but it soon will if nothing is done.
just trying to keep unauthorised / un-trained people out.
thanks
Old 11-23-2010, 08:13 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
You could order the keylock for the side of the control pendant. Then in the settings, you could set it to lock-out all of the possible changes (parameters, programs, offsets, etc). Keylock the pendant at night and it'll be safer (but not totally foolproof).
We have the same problem. I padlocked the machines the night they were first connected to power and lock them after use every day.
Greg
Old 11-23-2010, 09:04 PM
The keylock will lock out editing so you could make a practice of putting an M30 at the top of all your programs and just deleting it when you want to run a program. With editing locked out no one would be able to run a program.
An alternate if you can trace wiring and don't mind making modifications is to get any keyed switch and put it in the circuit for the power on button.
Old 11-23-2010, 10:35 PM
Pondo's Avatar
Pondo is on a distinguished road
Putting a note on the controller that says "STAY THE FOCK OUT OF HERE" didn't work?
Apparently I don't know anything, so please verify my suggestions with my wife.
Old 06-30-2011, 11:47 AM
*Registered User*
Travis P. is on a distinguished road
Memory Lock
Hello, I have a Haas TM-2 that has the key lock option on the side already. However we would like to explore other options too. I would like to see if there was a option in debug mode or such that keeps track of any personnel altering parameters or programs and such. The memory lock is way to simple for unathorized personel to figure out. Also is there a way to find out when a program was last eddited and added into the memory as a way to trace the time to an individual?
Thanks!
Old 07-02-2011, 11:12 AM
DaOne is on a distinguished road
Instal a key switch on the pendant and wire it in series with the power on button. When the key switch is off the power on button wont power on the machine.
Amazon.com: Key Switch with 2 Keys: Electronics Amazon.com: Key Switch with 2 Keys: Electronics
feed overide lockout? edward5 G-Code Programing 5 11-08-2008 08:41 AM
Spindle Lockout JTulley Tormach PCNC 0 11-06-2008 06:35 AM
Need Help!- Program/offset lockout I_flungdung Fanuc 3 05-08-2008 09:21 PM
