Hello good folks. Here's a good question !!... Is there a code to calculate within the program a G55 zero, given a G54 and knowing the distance between the 2 fo them ??. I'v seen this with OKUMA, you simply find and store the G54 zero offset and then when the program is running, it adds a constant to X and Y values to create the rest of the WCS... Thanks! |
| On Haas machines you can do something similar using G52, have a look at the manual for a description or do a search here using "Haas G52". I have posted some explanations previously.
| G'day David, You may be able to use a G10 to do what you are after. I know you can set an offset from within the program using a G10 but I'm not sure if you can offset one offset from another directly. There is a bit in the Haas manual about it. Regards, Dave.
__________________ Boulder Creek Tramway: www.smex.net.au/bouldercreek |
| how I can calculate the overpressureHi all,Could you tell me how I can calculate the | Lafaso870 | Mechanical Calculations/Engineering Design | 0 | 10-08-2010 04:38 AM |
| how to calculate this? | 15mgtar | Linear and Rotary Motion | 6 | 09-22-2009 02:49 AM |
| How to calculate this? | shakosh | Mechanical Calculations/Engineering Design | 9 | 09-30-2008 07:45 AM |
| Need Help!- How to calculate this? | shakosh | General Metal Working Machines | 4 | 09-25-2008 08:01 PM |
| How do I calculate this? | CNCadmin | Mechanical Calculations/Engineering Design | 2 | 02-05-2005 09:24 AM |
