I have a 1999 Haas VF4 with a direct drive spindle(no high, low gear box). When I start the spindle up from a stopped state I can go right to 7500 RPM and most of the time it will start right up. When I press spindle stop I will instantly get a alarm. The alarm number is 163 Spinlde Drive Fault. I will also get the alarm if I try to go from a low rpm (250 or so) to a high rpm (6000 or so). I have checked the incoming power and made sure the taps are set on the correct voltage. I am not sure where to go from there though. Any help is greatly appreciated. Thanks, Jeff
__________________ Jeff "Dirt is for racing, Asphalt is for getting there" |
| Yep, sounds like the regen. Shut the machine off and leave it sit for about 20 minutes to let the high voltage dissapate. Verify that the high voltage light is not lit on the vector drive and disconnect the regen at terminals 1&2 of the vector drive and measure resistance between them. If memory serves correct it shoud be about 8.4 ohms. If it does not measure correctly, contact your dealer for a replacement and have them confirm the ohms rating on it. Good luck. |
| Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? | pfeist | General Metal Working Machines | 11 | 02-13-2012 02:12 AM |
| Problem- HAAS VF2 vector spindle drive | crococh | Haas Mills | 7 | 04-02-2010 09:33 PM |
| Clausing Lathe Conversion, direct drive or reduced drive | Marty_Escarcega | Stepper Motors and Drives | 0 | 03-16-2010 10:43 AM |
| Need Help!- Direct Drive Plasma - Motor/drive/power supply? | CPierce18 | CNC Plasma and Waterjet Machines | 1 | 02-05-2010 05:53 PM |
| Need Help!- Direct Drive Plasma - Motor/drive/power supply? | CPierce18 | Stepper Motors and Drives | 0 | 01-29-2010 01:01 PM |
