Old 11-16-2010, 09:52 PM
OldReliable is on a distinguished road
Adding a constant to a probed Z offset
I need to probe 2 offsets in Z to compensate for some cockeyed parts. I am probing and setting G54 and G55 and need to add 1.137 to each and then make a cut to each offset. Am adding this to an existing historical program (thats how we've always done it!) to avoid the old way of measuring and shimming each part. How do I do it?
Thanks!
Old 11-16-2010, 11:10 PM
Black08Chally is on a distinguished road
I'm just going from memory with the 5223 address, do not use this until you confirm that is G54 Z!!!! I think this is what you are asking for.
(G54 Z OFFSET CORRECTION)
#5223=[#5223+1.137]
Old 11-17-2010, 08:35 AM
haastec is on a distinguished road
That will do it and #5223 is correct for G54 Z offset; they are listed in your manual if you need to use different.
Old 11-17-2010, 09:21 PM
Thanks guys!
Radius Offset and Length Offset jim_stoll Dolphin CADCAM 13 10-14-2010 07:47 PM
Need Help!- Adding an X axis power feed to my smithy 1220XL milling table.Adding an X axis power matridium Smithy 0 05-28-2008 10:37 AM
constant velocity help shnitzel Mach Software (ArtSoft software) 1 01-03-2008 08:10 AM
Scripting a constant offset curve over a contoured surface? Splint Rhino 3D 11 03-11-2007 04:35 AM
Constant offset tooling for er-16 impact Benchtop Machines 13 03-30-2006 10:17 AM
