2008 VF2 ![]() Is this correct? A. Coolant from pump B. Coolant to spindle C. Over flow return from spindle What is D and E for? They are connected together with an on/off valve into the supply cavity of the manifold. (???) D. E. |
| Here is what you need to do to pipe up the coolant correctly. Leave A with plug in. Unplug hose from E and connect the hose to the coolant pump. You should have a wash down kit that plugs into E instead. (the wash down kit is a length of hose approx twelve feet long with a spray nozzle on the end) B and C - (are piped correctly) one is hose to spindle head - the other is a wash down function inside the machine at the bottom of the Z axis waycovers. Hope this helps |
| You should be able to get a nozzle froma hardware store no problem. There is not normally a basket filter for the pump. There is on the lathes but not on a VF2. There is a basket on the new machines that fits under the coolant return to filter out swarf from returning coolant - but not a basket for the pump to fit in. Hope this helps |
| Tm Coolant Pump | behindpropeller | Haas Mills | 1 | 03-15-2010 10:45 AM |
| New coolant manifold | zephyr9900 | Tormach PCNC | 30 | 12-01-2009 02:55 PM |
| Coolant Pump Question | jamiedaugherty | General Metal Working Machines | 4 | 01-27-2009 06:57 AM |
| Need Help!- coolant pump | JACKSMACHINE | Fadal | 0 | 05-22-2008 03:13 PM |
| Haas VF2 Coolant Pump (Pressure) Question ... | Mike Braddock | Haas Mills | 6 | 06-09-2006 07:54 AM |
