Old 11-08-2010, 12:42 PM
behindpropeller is on a distinguished road
Coolant Breaker TM series.
Just bought a VF2 coolant tank and pump off of a shop that doesn't use coolant. I have read that I need a different breaker.
Anybody have the OEM PN of the breaker? I think I need to go from a 2A to 10A?
Tim
Old 11-09-2010, 06:01 AM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
breaker
Yes, you need a 10 amp breaker if you have the 3/4 HP High Output Pump.
That should be a no brainer for your local HAAS HFO. Just tell them you need a 10 amp breaker for your coolant pump.
John
2007 HAAS TM-1P OneCNC XR4 Mill Pro. Shopbot PRT running Mach3, 2010 Screen Set, Super PID and PMDX Electronics. Check out my Gallery on: http://www.helicopterjohn.com/
Old 11-14-2010, 01:03 PM
FYI:
Breaker is PN 61-7300.
Swarf in Coolant on Series I ranchak Bridgeport and Hardinge Mills 4 12-15-2009 10:12 AM
Breaker size? Delw Haas Mills 3 06-05-2009 07:13 AM
VF-2ss coolant breaker extanker59 Haas Mills 3 10-22-2008 10:18 AM
Using mist coolant with Hillbilly board (Series I BP) Mr. Technical Bridgeport and Hardinge Mills 9 11-19-2007 09:01 AM
Bit breaker CNCadmin Mach Mill 6 11-22-2005 06:33 AM
