Old 11-05-2010, 10:35 AM
dahui's Avatar
dahui is on a distinguished road
OLDER Haas VF1 and thread milling?
Hi folks,
I'm considering a used (1992) VF1...white and black enclosure with the rounded edges...and I have a couple of questions.
First, does anyone know what pin configuration the rotary axis uses? I have a Haas (old!) 5c stepper indexer (black finned motor housing) with a 7 pin output and wondering if this is the correct vintage machine to match it
Second, it doesn't have rigid tapping. I can get a tapping head for the small stuff, but I need to do a lot of 7/8"-2" diameter threads. So, I'm wondering if this machine can thread mill. It's been years since I've written code for thread milling so I can't remember if there is a specific g code for that or if you can manually combine circular interpolation with a Z move. I will be doing a lot of thread milling, so I'd like it to be reasonably trouble free.
I have to decide asap so extra points for fast responses! Thanks in advance.
Old 11-05-2010, 01:45 PM
HuFlungDung's Avatar
Moderator
Sorry, I don't know anything about your 4th axis.
I would recommend that you go to the Haas website and download the mill control workbooks. There is plenty of good info in there. It may not all apply to an older machine, but it can be better than thrashing in the deep end
They give an example in there of how to do thread milling with arc commands, using cutter radius compensation and repeated passes. So it is not a special gcode per se, but a special command line.
Or you could go with a software thread milling solution. There are various thread mill wizards available from some of the thread mill manufacturers. Of course, you have to cut and paste the code. The code is longhand: written out in full so that any controller can cut it with simple helical command movements.
OneCNCXR4 provides a software thread milling facility that allows you to include the thread milling code right in its nc manager so it is all neatly included in your regular machining files, which makes for easier file-keeping. OneCNC also permits fancier things like 'overlap' on the thread mill pass so as to ensure there is no raised blip on the threads, and an inclined approach/depart so that the thread mill doesn't score the threads as it enters/exits the cut. This can be a concern when the thread mill is large in proportion to the hole it is working within.
older haas 200 program limit cherokeechief79 Haas Mills 11 10-03-2011 04:33 PM
Thread Milling Don Clement Tormach PCNC 23 08-01-2011 06:48 PM
Need Help!- G76 Thread cycle Haas SL-30 haaszard ahead G-Code Programing 7 06-30-2010 01:08 AM
Replacing rear cooling fans on older Haas VF-0 lkenney Haas Mills 0 12-19-2008 10:39 PM
