Old 10-24-2010, 07:26 PM
kfarny is on a distinguished road
How do I download all programs to the floppy disc at once? (VF3)
Is there a way to "copy all"?
I would like to backup all of my programs to the floppy disk at one time on a monthly basis. Since we are going to be buying a HAAS lathe soon, this is goiung to be more and more important.
Any suggestions?
Old 10-24-2010, 08:58 PM
ntcnc is on a distinguished road
I am not at my machine but I believe if you scroll down your program list the last program should be named "all" selecting that should get them all.
Old 10-25-2010, 01:35 AM
ntcnc is correct but you do have to put in a file name before you hit write to floppy.
The programs all copy as a long string and it can be tedious trying to separate them out if you want to copy a single program back to the machine.
Old 10-25-2010, 09:46 AM
KenFoulks's Avatar
KenFoulks is on a distinguished road
Your new lathe will come with USB, which has a "backup" feature that can download all programs/settings/parameters/offsets/macros/history/key history/Advanced Tool Management values/probe variables/all
Thanks,
Ken Foulks
Old 10-25-2010, 12:31 PM
locash is on a distinguished road
What is the procedure for doing the full backup on a usb machine? Will it backup the unlocked parameters, or will we need to re-enter the unlock codes upon reinstallation as well?
Old 10-25-2010, 01:57 PM
Haas__man is on a distinguished road
The procedure to back up 'ALL' is below:
Go to USB page
press F4
move cursor down to 'save all'
type filename but with no extension, for example BACKUP1
The machine will now save around 8 files to your USB
BACKUP1.SET (settings)
BACKUP1.PAR (parameters)
BACKUP1.OFS (offsets)
BACKUP1.VAR (macro variables)
BACKUP1.HIS (alarm history)
BACKUP1.PGM (programs)
etc
Backing up the system is easy - but using the recovery disk after memory problems should only be done by a service tech. A backup would be very useful to a service tech, so is definately worth doing.
Unlock codes are not saved in backup files - they would need to be re-entered.
Hope this helps
Need Help!- Download programs from controller thru RS232 CzechMarty Daewoo/Doosan 5 10-09-2009 06:29 AM
Need Help!- How does a software disc... IQChallenged General CNC (Mill and Lathe) Control Software (NC) 25 10-28-2008 08:50 AM
Need Help!- Saving programs -Floppy drive ? chipsinpan Milltronics 4 05-16-2008 09:36 AM
Upload/download programs with RS232 on lynx with Mitsu 50L controller Chuck Reamer Daewoo/Doosan 10 03-17-2008 12:42 PM
application for separating individual nc programs from cnc machine download shawncnelson General CNC (Mill and Lathe) Control Software (NC) 0 07-09-2006 07:28 PM
