Old 10-24-2010, 05:51 PM
bostosh is on a distinguished road
Table Slot Center -to Center distance
I am building a fixture 28 x 18 x 1.5 and wish to know if Haas has a standard "Center to Center" distance for the "T" bolts on the machine table, and if you know numbers for other machines too?
I am trying to make it fit anybody's machine bed.
Now I have two centerline bolts and 6 slots in y, which will cover from + and -Y 3.5" to 7.5"
Here is a picture Thanks in advance guys
http://members.cox.net/bostosh0/Tool...0%20PlanVU.pdf
Been doing this too long
Old 10-24-2010, 06:49 PM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Haas has a PDF with all the machine dimensions for each machine right on their website. It includes the table dimensions, T-slot sizes, spacing, etc. It'll take a few minutes to download all the models you're interested in but, that'll answer it for you quickly.
Greg
Old 10-25-2010, 09:41 AM
KenFoulks's Avatar
KenFoulks is on a distinguished road
There are several standard sizes, here is a selection of machines with their t-slot spacing:
4.92" or 125mm (VF-1, VF-1YT, VF-2, VF-2YT, VF-2SS, VF-2SSYT, VF-2TR, MINIMILL2, SMINIMILL2)
4.33" or 110mm (MINIMILL, SMINIMILL)
3.15" or 80mm (VF-3, VF-3YT, VF-4, VF-3SS, VF-3SSYT)
The rest of the dimensions can be found here:
Haas Automation, Inc. | CNC Machine Tools | The Leader in CNC Machine Tool Value
--Navigate to the appropriate machine and select dimensions.
(note: Some t-slot dimensions are to center line, not slot to slot)
Thanks,
Ken Foulks
emco compact 8. distance from center to top of compound jmdias1125 EMCO Lathe 1 11-23-2010 07:36 AM
Bring table to center bowmaster Haas Mills 10 07-25-2010 10:17 PM
Recommended center diameter for center rest CAMCRASH General Metalwork Discussion 2 03-30-2010 12:58 PM
Need Help!- Best way to center rotary table Micro Milling General Metal Working Machines 6 12-30-2009 08:50 PM
spindle to center of X&Y table? ZipSnipe General Metal Working Machines 1 07-26-2006 07:05 AM
