I need to mill out a rounded bottom cavity but I need to tool comp for my 1/2 inch ball endmill. Before you ask, No I can not get the CAM software to do the comp. So can I get the Haas to do tool comp if I select the x-z plane then just do a G41 or G42? Does this even work? |
| I mean, if he is cutting a rounded bottom cavity using XZ moves, can't he just G43 tool comp/tool length offset to adjust for the depth? If he is using XY moves with stepped Z, he also use G43 to adjust for depth and G41 to adjust for the XY dimension of the cavity, right? Does using XZ moves for round cavities give a better finish? |
| Depending on your control, you will have to give it a command to change to an XZ plane, G17 is the XY plane for a Fanuc Style Control, If I remember right, I'm old. the G18 or G19 command will change the cutter plane to an XZ plane which will allow you to use your current cutter comp number and the same offset table for cutter dia. But remember that you will have to imput the G17 command in the next line to bring you back to normal XY programming. |
| Rapid tool moves when not cutting? | Fleck | G-Code Programing | 2 | 04-22-2009 01:26 AM |
| tool comp | blighty | Mach Mill | 2 | 01-07-2009 08:14 AM |
| Need Help!- Tool comp questioin | JV58 | Mazak, Mitsubishi, Mazatrol | 5 | 04-23-2008 07:08 AM |
| Fanuc 11m Tool Comp | Jfrahm | Fanuc | 5 | 07-29-2007 05:01 PM |
| Cycle Time for Rapid Moves and Tool Changes V9.1.1012 Turn | jmullett | Dolphin CADCAM | 1 | 02-07-2007 04:32 AM |
