Old 10-21-2010, 01:02 AM
cncJ is on a distinguished road
Renishaw variable change? How to
How exactly I can change Renishaw variables? I have HAAS with renishaw measuring probe. So i need to change for example this #562 back off distance, but how do I do it? Do i write it to MDI some how, or is it in parameters or somewhere?
Old 10-21-2010, 02:07 AM
guypb is on a distinguished road
Look in Program 9724...
Alter
N600
#[ #161 + 6 ]= 0.2
Where:
#161= 556 (START CALIBRATION VARIABLE)
This value (0.2) is NOT an absolute distance but a factor - a smaller factor reduces the back-off distance.
I would strongly suggest NOT changing the base variable from 556 as you may conflict with the tool setter variables!!!
If you intend to fix the factor, it is probably best to recalibrate also just in case. (though metrology wise the back-off shouldn't affect performance)
Old 10-21-2010, 08:43 AM
pit202 is on a distinguished road
I`ve changet #556 to 0.05 half year ago , and I am more happy than before , faster cycles and never had any collision.
Current and commands -> few times PG DN ( until macro variables ) -> few times arrow DOWN ( until see the #556 ) and type your value.
Peter
Old 10-21-2010, 10:05 AM
JWK42 is on a distinguished road
Don't use #500 series variables
After reinstalling the renishaw software about 4 times we decided to change all our progams with #500 series variables to #600 series and have had no more problems. Thank goodness for "search & replace"
I am amazed the the probing software doesn't protect the varianles they use.
Love our probes!!
Change variable by MDI aidoru Fanuc 20 03-25-2010 10:02 AM
EMC2 variable pitch / variable diameter threading. samco General Metalwork Discussion 0 03-09-2008 01:40 PM
variable to change tool offsets in auto cycle dalvinder Machine Problems, Solutions , Wireless DNC, serial port 0 09-04-2007 03:45 PM
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 02:58 PM
variable speed dial reconnection, or drive belt change? klysons Tree 1 06-29-2007 09:30 PM
