Old 10-16-2010, 02:54 AM
gernap is on a distinguished road
Question visualcam/mill post issue
I wonder if someone had the same problem as i do now!
I use visualmill 6 and try to change the post processor for my haas minimill.
when using threadmilling my post only works with conversion helical moves to little line segments because i get an error with I J K acurracy when i using G03 operation, i know that haas can make helical and spiral moves with G12 and G13 but how do implement that in the post ? from mecsoft i did not get an answer yet
has anyone an working post for haas ?
Old 10-18-2010, 10:35 AM
KenFoulks's Avatar
KenFoulks is on a distinguished road
You should be able to adjust the precision of the output, instead of I1.03, it will output I1.0265. It may be post-specific, file-specific, machine-specific, or an overall software setting. This may solve your problem.
Thanks,
Ken Foulks
Old 10-18-2010, 05:49 PM
thanks, i will try to change this setting, i will post the results here
Tags
haas, post, postprocessor, visualcam, visualmill
G0704 mill- first impressions/issue wolfend Benchtop Machines 10 12-27-2010 05:48 PM
Need Help!- visualcam to rover c6 davidrole CNC Wood Router Project Log 0 04-09-2010 05:02 AM
de visualcam a rover c6 davidrole Spanish CNCzone 0 04-09-2010 03:45 AM
Need Help!- 4th axis issue in Visual Mill 5.0 Shawn_ Visual Mill 2 03-20-2009 11:07 PM
Mach issue with my mill Rich05 Mach Software (ArtSoft software) 3 11-30-2008 05:00 PM
