Old 10-15-2010, 03:38 PM
jwool814 is on a distinguished road
Cool What is the meaning of "D17"
Trying to cut angles with a D17 code on a VF-2 Haas.. Trying to offset X and cannot get the angle right. Please help!
Old 10-16-2010, 12:10 PM
Delw is on a distinguished road
D17 is a tool diameter offset for tool 17.
the "D" is the code that tells the machine your going to use a diameter offset the number after that would be the number of the tool.
the only effect is has on a making a angle wrong is if your start and end points are wrong, or your using the wrong offest dim.
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Need Help!- "Warco GH Univ" V "Chester Lux Mill" JQ_Quint Benchtop Machines 37 01-22-2009 10:59 AM
G320 "common" or "+5vdc" why do they vary? beezerlm Gecko Drives 3 01-12-2008 04:00 PM
