Haas did an inspection on the 08 VF2 I purchased and rated it 9 out of 10 because of the rust. The machine only has 3 cutting hours on it, so it's a bummer that the rust is as bad as it is. I've spent some time working on the rust with steel wool but it's not going real well and I'll never get it done with this approach. The steel wool won’t even touch the rust on the weigh covers anyway, plus it's all but impossible to get all the rust out of the tee slots. I got the table top pretty clean compared to the rest of the machine, but I'm not completely happy with it. If I'm ever going to clean this machine up I need to do it now, otherwise it's not likely I'll get to it later down the road. I've used a technique in the past for removing rust from steel called electrolysis rust removal which is truly amazing to say the least. I know it would work well for this but I would have to do some disassembly in order to use the process. I'm just unsure of what I would be getting into by taking this thing apart and not sure what parts I would have to buy for proper reassembly (If any, gaskets? Wipers?) The company I purchased this from did attempt to use naval jelly to remove the rust but really made a piss poor attempt of it; they did succeed in stripping some of the bluing from the chip tray but not much else. I live in Arizona so the moister is minimal, putting the effort into this wouldn’t be totally in vain. I’m just not sure if I’m overly worried about the rust or not, what do you guys think, any suggestions? Chip tray> ![]() ![]() Spindle covers, it kind of looks like oil or something in the picture, but it is rust. > ![]() Tee slots> ![]() A few more >> ![]() ![]() ![]() ![]() Also, should this hole have a plug in it? What is it for?> |
| I'm not sure I would remove the waycovers and have them processed as the waycovers have two main functions, keep debris and coolant away from what is behind them and to slide freely. If the covers are damaged during dis-assembly or installation, the covers could bind and fold up. ![]() I would remove any "raised" rust areas with scotch brite and finish with some steel wool just to make sure that the covers are allowed to move freely and again not bind. As far as the hole in the bottom of the spindle head, I believe cables and/or air lines are run through those hole for the P-Cool option and an air blast setup. Since it's a path to the inside of the spindle head assembly, it should be plugged. BTW, good find on the VF-2 with 3 hours. |
| You don't need to dissasemble everything to do reverse electrolysis- simply slap an old towel soaked in the electrolyte on to the part to be de- rusted, stick a smaller copper plate on top of it- that's your first contact, the second is the part you're de- rusting. Such a simple idea, unfortunately not thought up by me so Kudos and respect to Mr Frank Ford. Here's the link: Look for "Killing Rust While It Sleeps" http://www.frets.com/FRETSPages/Mach...stremoval.html KURUST is quite handy too- I've used that a few times- it's like a thin paint you apply and it kills the rust. Turns it black though. Worth checking out though.
__________________ I love deadlines- I like the whooshing sound they make as they fly by. Last edited by ImanCarrot; 10-12-2010 at 04:57 AM. |
EDIT: It was easy to find, thanks again. |
| Not to burst any bubbles, but regarding the 3 hours on the machine; are you looking at the page that shows power on, spindle, and feed time? If so, be aware that all three of those displays can be zeroed out by highlighting each one and pressing the origin button. The true hours of the machine are displayed on a hidden screen only accessable by entering the debug mode. |
| I think your worried too much about this. I'd just hit the bad rust spots on the waycovers with a scotchbrite pad, and start making chips. Stone the table before you mount your vises or subplate. I have a 94 fadal that had some rust and corrosion on the way covers from the previous owners toilet water coolant. After a few years of use with good coolant most of the corrosion is gone. I can still see a little of the pitting but no rust. Have fun making chips with the new machine |
| Are the way covers stainless steel? If so, do not use steel wool. It leaves micro bits of regular steel imbedded in the stainless and will rust quickly. Naval jelly uses phosphoric acid to remove rust. It is easier to spray phosphoric acid and use a good stainless or brass brush to remove rust. You can get acid cleaner at a welding supply. |
#11
#12
| You use copper, does it make a difference? I am very interested in this method of removing rust because I have never heard of it and I can see a great value for the process. Thanks for bringing this to our attention.
__________________ Regards, Carl |
| Preventing rust | technocrat | General Metalwork Discussion | 7 | 12-09-2008 03:05 AM |
| Newbie- rust | 3axisrookie | General Metalwork Discussion | 13 | 08-27-2008 05:21 PM |
| Need Help!- Rust on Ways | bctruett | Sharp CNC | 4 | 03-09-2008 10:15 AM |
| Reconditioning and rust | ozzie34231 | General Metalwork Discussion | 6 | 12-11-2007 02:18 PM |
| rust prevention | coolman | General Metalwork Discussion | 2 | 01-22-2005 11:32 PM |
