Old 10-11-2010, 10:57 AM
Alex VF is on a distinguished road
Haas VF-1 '95 Shuttering
Hi everybody,
When I mill on my Haas VF-1 (model 1995) it shatters every time it changes from a G-code to another (for example from a G01 to a G02 code). I checked out the parameters but I could not find a solution. The VF-0 which we have (model 1995 but older that the VF-1) does not shatter at all and works very smooth.
This shattering occurs even at low speeds.
Does anybody know hot to solve this issue?
Thank you.
Alex
Old 10-12-2010, 11:20 AM
KenFoulks's Avatar
KenFoulks is on a distinguished road
Try adjusting these settings:
191=Finish
85= about .005
You can also try toggling your High Speed Machining (HSM) ON/OFF
Thanks,
Ken Foulks
Old 10-12-2010, 12:34 PM
haastec is on a distinguished road
Are you having finish issues or noise issues? Or both?
Old 10-18-2010, 09:08 AM
Hi guys,
Thank you for your efforts.
Ken; I looked for the 191 code but I did not find it. Where should I look for the HSM?
Haastec; I do not have finish issues but I would prefer that the machine would work more smooth. It also stops when it is milling a circle and it changes from quadrant (for example from +X to /-X).
Alex
Old 10-18-2010, 09:38 AM
You could have a loose ball screw which would cause the issues described. If you are comfortable doing this, pull back the left X-axis way covers. With the machine in E-stop, grab the ball screw and feel for excess play. Also, if it is loose, you will see the ball screw move before the table does. If this is the case, try tightening the ball screw nut located under the gold cover plate by the motor and see if this helps your situation.
Also, if you have been running this machine without issue and this problem just came up, I would highly doubt that it is a parameter issue.
Good luck.
Old 10-18-2010, 09:51 AM
Haastec,
Thank you for your reply. I will check it tomorrow and inform you. Do you know whether this might also be a setting on the machine that can be changed?
Old 10-18-2010, 09:52 AM
KenFoulks's Avatar
For setting 191: Go to settings, type "191" and press down.
For HSM: Go to parameters, type "315" and press down six times.
Thanks,
Ken Foulks
Old 10-18-2010, 09:56 AM
Ken,
I checked the parameters but I do not have these parameters (291 and 315). Maybe you are referring to a newer model? Mine is a 1995 model.
Old 10-18-2010, 10:29 AM
KenFoulks's Avatar
Setting 191 and parameter 315 were developed after 1995, but setting 85 should be there.
Thanks,
Ken Foulks
Old 10-18-2010, 10:36 AM
Ken, thank you. I checked it already and the current value is 0,500 (the same value as on the VF-0 which does not shutter), but I will change it tomorrow to see what happens. I will let you know.
  #11   Ban this user!
Old 10-19-2010, 10:18 AM
Ken,
I changed the parameter 85 to 0,005 but unfortunately it did not work. thank you anyway for your help.
  #12   Ban this user!
Old 10-19-2010, 07:07 PM
Pondo's Avatar
Pondo is on a distinguished road
If you look at the G code you are running, is there a G187 line in it?
Our programmers used to put that in the post after every tool change. It overrides the accuracy control (setting 85) to whatever the E value is.
If you go one page down from your normal current commands screen you can see all the active codes and values as the machine runs. The E value is on the far right and all the way down. If it is not the same as your setting 85 value (.005 or so for instance) then it is being overridden.
Also, are you running the program from the control or DNC?
Apparently I don't know anything, so please verify my suggestions with my wife.
haas SL-20 to Haas bar 300 alignment plate needed J-Mccoin 2009 Haas Lathes 2 12-02-2009 09:13 PM
RFQ haas SL-20 to Haas bar 300 alignment plate needed J-Mccoin 2009 Employment Opportunity 0 10-28-2009 02:17 PM
Haas Super Mini-Mill and Haas Trunnion Table Gabe Newell Haas Mills 6 06-07-2009 01:23 PM
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
HAAS Service HAAS Repair NY NJ CT PA serviceman Product Announcements & Manufacturer News 1 01-04-2008 03:27 PM
