Results 1 to 2 of 2
Thread: renishaw probing on haas mini mill
    Sep 2010
    trying to probe .125 dia, probe tip is .078, cant seem to control back off distance, runs into opposite side, is it possible to control with variable, using 9814
    Apr 2005
    Paradise, Ca, USA
    Variable #562 controls back off distance of the probe. You can set it within your program:
    #562=.015
    Then, at the end of your probing routines, if you feel the need, just set it back to whatever is standard, which I think is .200".
    If you are probing for size, you may want to verify you get good numbers with the back off so small.
  1. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 02:23 PM
  2. Problem- haas mini mill
    By johnmckeown in forum Haas Mills
    Last Post: 02-19-2009, 11:26 AM
  3. Haas mini mill
    By pyroracing85 in forum Haas Mills
    Last Post: 05-11-2008, 08:33 PM
  4. Renishaw probing -- NON VQC
    By gromit68 in forum Haas Mills
    Last Post: 01-19-2008, 10:34 PM
  5. Renishaw probing setting workshifts
    By Liontastic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2007, 03:25 PM
