Old 09-15-2010, 09:23 AM
JWK42 is on a distinguished road
Regrind taper on Cat 40 tools
We are trading our Haas HS1-RP for a Haas EC-400 with probe and full fourth axis. I am wondering if we can have the tapers on the Cat 40 tools off the HS1 reground. I know it would change the gage length. We never put old tools in a new spindle. But we have a lot to tools for the HS1. Other wise we will buy a new tool package.
If anyone needs a HS1-RP. I think the HFO would be glad to deal on it.
Old 09-18-2010, 10:41 PM
lkenney is on a distinguished road
Why wouldn't you use the tooling you have without regrinding. Shops move tools around to different machines all the time? I would think that regrinding would cause more problems than just using the tool holders unless they are spalled or warn out.
JMHQ
Lowell
Old 09-18-2010, 11:41 PM
HuFlungDung's Avatar
Moderator
Yes I'd also have to wonder at regrinding the tapers and getting them perfectly concentric with the tool holding bore.
I suppose that the original manufacturer has a perfect spindle to hold the taper shank while the working end of the toolholder is finish ground. But working in reverse would be an expensive PITA.
Ballscrew replacement/regrind? jetblackaircraf Linear and Rotary Motion 0 05-01-2009 05:26 PM
Lot of 45 taper tools needs a home.. tnik General Metal Working Machines 5 10-03-2008 06:27 AM
Deckel SO-E cutter grinder regrind laurentian Deckel, Maho, Aciera, Abene Mills 0 02-19-2007 04:30 PM
Source To Regrind Endmills imwllc General Metalwork Discussion 3 07-20-2005 11:49 PM
Regrind toolholders I.C.O.N. General Metal Working Machines 0 03-26-2004 10:43 AM
