Old 09-13-2010, 02:09 PM
s00073055 is on a distinguished road
hass Z axis problem
Hi all, i have a 105 alarm on my 94 Hass vfo on the z axis, it will not zero return i can get the z axis to move down towards the table but if i try to move it up away from the table i get the alarm again. i was also wondering what kind of counter balance system this machine has, thanks
Old 09-21-2010, 09:13 AM
KenFoulks's Avatar
KenFoulks is on a distinguished road
In 1994 there was a shift from Counter Weight to the Hydraulic counterbalance. The Hydraulic counterbalance are easy to id by Hydraulic tank mounted on the column of the machine. The alarm 105 can because by overload on the motor due to mechanical binding, faulty motor, motor cable or drive card. To test for mechanical binding turn off the machine and lock it down for safety and drop down the Z axis way cover and try to turn the Z axis ball screw by hand it should turn freely on both directions.
Thanks,
Ken Foulks
Old 09-21-2010, 01:20 PM
thanks for your answer, i have traced my problem to the z axis drive card, i am trying to fault find the card at the moment the card will allow me to jog the z axis down but will not allow me to jog upwards this is when i get the 105 alarm.
Regards
Denis
Old 09-21-2010, 02:12 PM
haastec is on a distinguished road
Have you tried to swap the Z-Axis card with either x or y to see if the fault follows to the same axis. Otherwise do as Ken mentioned and see if Z-Axis ball screw turns freely.
Old 09-21-2010, 03:03 PM
hello thanks for the reply i swapped the z card with the y card and the problem moved as well so the card is the problem now finding the fault on the card is the problem it may not be worth repairing as some components can be difficult to source i will also have to check the z axis motor as it may have cause the card to fail.
regards
Denis
Hass 5 axis Mill Integrexman Videos 2 07-25-2009 02:28 PM
hass d offsets antny OneCNC 8 07-19-2009 09:50 PM
Hass VF-5 post arc/line interpolation problem meadowtech FeatureCAM CAD/CAM 1 06-11-2008 08:06 AM
Need A Quote- looking to buy USED HASS CNC mill H_U_S_S_A_M Want To Buy...Need help! 0 04-23-2008 04:46 PM
Wireless RS-232 to Hass VF-2 Gujustud Machine Problems, Solutions , Wireless DNC, serial port 1 04-12-2006 04:44 AM
