Hi, I reapir motor bike Heads on my HS1 Horizontal, programs have been created on surfcam by a programmer, but i want my Independance , I have a internal Hole bored to 19.15MM and want to generate a 18 tpi right hand thread,(internal) Can this be done on the HS1 without surfcam? My boring bar is 20 MM diameter with a 55 degree insert, The thread is started at the bottom of the hole , Any tips will be appreciated, John, BRIT Bike Nutter, |
| I'd recommend you go to the Haas website and download the mill control workbook (available in a pdf file). There is a section in there (page 70) on how to threadmill using simple commands. It is better that you fully understand what is going on, because some tinkering is usually required to get exactly what you need to produce.
__________________ Apparently I don't know anything, so please verify my suggestions with my wife. |
| I programmed it up quick. Here's a 20mm dia tool cutting an 18 TPI thread, 39.15 dia start hole, 1.625" OD of the thread. Starts @ Z-1. and cuts CCW up to Z.050. % O2024 ( THDMILL.TXT ) ( T1 - THREAD MILL ) G17G40G80G90G0G54 N1 T1M6 ( OPERATION 1; THREADING ) ( TOOL 1; .7874 THREAD MILL ) ( THREAD MILL ) S6000M3 G90G0G54X0.Y0. G43Z3.H1M8 Z.1 G91 G1Z-1.11F42. G41G0X.0752Y.0752D1 G1X.0139Y.0071 G3X-.0891Y.3365Z.01I-.0891J.1565 Z.0556J-.4188 Z.0555J-.4188 Z.0556J-.4188 Z.0555J-.4188 Z.0556J-.4188 Z.0555J-.4188 Z.0556J-.4188 Z.0555J-.4188 Z.0556J-.4188 Z.0556J-.4188 Z.0555J-.4188 Z.0556J-.4188 Z.0555J-.4188 Z.0556J-.4188 Z.0555J-.4188 Z.0556J-.4188 Z.0555J-.4188 Z.0556J-.4188 X.2462Y-.08Z.05J-.4188 X-.2699Y-.2198Z.01I-.1059J-.1456 G1X.0071Y-.014 G40G0X.0166Y-.105 G90Z.1 M9 G91G28Z0.M19 G91G28Y0. T1M6 M30 %
| Also, what kind of bike are you working on? I have the top end off of my '04 V-Rod right now, I'm getting it back running tomorrow. I do bike parts for a hobby.
| M36x4 internal thread need good threadmill??? | mt92 | CNC Tooling | 0 | 04-06-2010 03:14 PM |
| turning 1/4-20 internal thread | Runner4404spd | Mini Lathe | 3 | 09-20-2007 01:43 AM |
| 5"-4un Internal Thread Specifications | SheldonB | Mechanical Calculations/Engineering Design | 2 | 05-12-2007 02:54 AM |
| Method to internal/external thread ? | PeteGallo | General CAM Discussion | 6 | 04-03-2007 09:50 AM |
| Internal Thread Grinders | Zumba | General Metal Working Machines | 4 | 03-03-2007 08:28 AM |
