Hi All, Hope someone can help with my little problem. I'm having trouble trying to m/c a spiral on a flat milled face, what i'm trying to achieve is basically create a turned finish in the form of a continuous spiral using a small pointy engraving tool. I have a macro to generate lots of circles incrementally but with the dwell and the start position being close together it leaves what looks like a line across the face which is not acceptable. |
| http://www.cnczone.com/forums/showthread.php?t=110522 Take a look at samu's posts #12 & #14 in this thread. The only other alternative I know of for a precise spiral is many small linear moves - if your control is fast enough to perform calculations. A Heidenhain version of this method was discussed here: - http://www.cnczone.com/forums/showthread.php?t=105697 DP |
| Mastercam has a nice helix boring feature and Gibbscam has a threading feature that can be used the same way. They post out continuous helical spirals at whatever pitch you'd like, OD or ID. I'd approach it as if it were a very fine pitch thread you're cutting and I think it will turn out better.
__________________ Apparently I don't know anything, so please verify my suggestions with my wife. |
| Here is a macro I use to mill spiral face grooves in out parts. Maybe you can adapt it to your needs % O5555 (SPIRAL GROOVE MACRO) N30 ( WRITTEN 09-07-2010 08:42:13 ) N40 (MODIFIED 09-07-2010 13:45:59) N50 #101=1 ( END MILL ) N60 G17 G54 G90 N70 G40 G49 G80 N80 G53 G00 Z0. N90 G53 G00 X-16.0 Y0. ( TOOL #1 IS A MILL ) N110 G53 G00 Z0.0 ( RESTART TOOL #1 HERE ) N120 G53 G00 X-16. Y0. N130 T#101 M6 N140 S124 M3 N150 G53 G00 Z4.0 N160 G54 G00 G90 X0. Y0. N170 G43 Z2. H#101 D#101 M8 N180 #601=.1 ( STARTING RADIUS ) N190 #602=0 ( STARTING ANGLE ZERO = 3 O:CLOCK ) N200 #603=1 ( SET #603 TO -1 TO MINUS RADIUS 1 TO PLUS RADIUS ) N210 #613=-1 ( SET #613 TO -1 FOR CLOCKWISE MILLING 1 FOR C-CLOCKWISE ) N220 #604=.25 ( FULL CIRCLE PITCH OF ONE GROOVE ) N230 #605=90 ( NUMBER OF STEPS PER 360 DEGREE CIRCLE ) N240 #615=4 ( NUMBER OF FULL OR PARTIAL CIRCLES OR GROOVES ) N250 #625=6 ( CUTTING FEED RATE ) N260 #626=3 ( PLUNGING FEED RATE ) N270 ( END OF INPUTS ) N280 #624 =[#615*#605] ( TOTAL NUMBER OF STEPS ) N290 #606=[[#604/#605]*#603] ( STEP RADIUS ) N300 #608=[[360/#605]*#613]( STEP DEGREES ) N310 IF[#613 EQ 1]#623=3 ( MILL C-CLOCKWISE ) N320 IF[#613 EQ -1]#623=2 ( MILL CLOCKWISE ) N330 #610=[COS[#602]*#601] N340 #611=[SIN[#602]*#601] N350 G00 X#610 Y#611 N360 Z.1 N370 G01 Z-0.25 F#625 N380 WH[#624 GT 0]DO1 N390 #624=[#624-1] N400 #601=[#601+#606]( STEP RADIUS ) N410 #602=[#602+#608]( STEP DEGREES ) N420 #610=[COS[#602]*#601] N430 #611=[SIN[#602]*#601] N440 #612=[SQRT[[#610*#610]+[#611*#611]]] N450 G#623 X#610 Y#611 R#612 F#626 N460 END1 N470 G01 Z.1 F50. N480 G53 G00 Z0. M9 (UNLOAD HERE) N500 G53 G00 X-16. Y0. N510 M30 (END OF MAIN PROGRAM) % Last edited by JWK42; 09-08-2010 at 09:07 AM. Reason: fixed line N450 |
| DP By golly you are right. We fixed it at the machine but never in the office. It does work pretty well. I have never used it to mill a round hole. Would have to add a line to make a full circle cut after the final spiral. |
| MACRO FOR HOLE SPIRAL MILLING | ALEXCOMO | Fanuc | 32 | 06-23-2011 06:37 AM |
| Cutting a Spiral with G02/G03 CNC88 | donl517 | Fadal | 24 | 02-15-2010 07:00 AM |
| Constant cutting speed macro | MrWild | Dolphin CADCAM | 4 | 06-10-2008 05:18 AM |
| spiral macro ? | cyclestart | G-Code Programing | 4 | 03-23-2008 09:42 PM |
| Convert Fanuc Macro to Fadal Macro | bfoster59 | Fadal | 1 | 11-08-2007 11:41 PM |
