Old 09-05-2010, 01:32 PM
aadrew10 is on a distinguished road
Tool Offsets and Z position display in hand jog
Hello,
I have not been able to figure out how to make any of the 4 position readouts give the position of the tip of a tool in the Z direction. I would ideally like to be able to change through tools, and then be able to scroll down to Z0 with each tool, and have that position be at the zero point of my work piece. While a program is running, the readout shows the z height of the tip of the tool. I would like to get it to do this in hand jog mode. I hope this makes sense. Any info is much appreciated.
Thanks,
- Andrew
Old 09-06-2010, 02:51 AM
Delw is on a distinguished road
Hit the post bit key a few times it will give youa few different options axis position options
Old 09-06-2010, 03:32 PM
Matt@RFR is on a distinguished road
As far as I know, the only way you can do that is to program a move to a known height in MDI, then zero the operator position screen, then make incremental moves from there in handle jog mode. For instance, if you have G54 Z set to the top of your part:
G0 G80 G90 G54;
G43 H1;
Z0.
From there, you zero your readout and move around.
Old 09-06-2010, 09:59 PM
Pondo's Avatar
Pondo is on a distinguished road
G0 G80 G90 G54;
G43 H1;
Z0.
Yep.
I keep this in MDI:
G90 G00 G54 G43 Z2. H1;
M30;
Then I change the H callout to the tool in the spindle. Once it gets to the position, I set the Z to 2.0 on the operator position page. You can add X0. Y0. to it and set those axis as well.
Apparently I don't know anything, so please verify my suggestions with my wife.
Old 09-06-2010, 10:03 PM
Thanks for the tips guys.
Problem- 21iT: Using 2 offsets for 1 tool:Machine stops for tool change gnmachine Fanuc 4 02-01-2011 08:10 AM
Position Display on Multus zooloader Okuma 1 04-09-2009 10:37 PM
setting the tool data and the tool offsets Michael82 Mazak, Mitsubishi, Mazatrol 6 01-23-2009 01:50 AM
Need Help!- DYNAPATH 20, WHEN E-CODE IS ENTERED, POSITION DISPLAY DOES NOT UPDATE. WEBBERS_14 General Metal Working Machines 0 08-28-2008 10:09 AM
Position Display on fanuc 6m fredf1 Fanuc 1 10-22-2005 04:08 AM
