Old 09-03-2010, 11:12 AM
Ecmdrw5 is on a distinguished road
Mirrored Engraving
I want to mirror some text and part numbers into a part. I can't mirror the whole program because of other pockets and holes. Any ideas?
Old 09-03-2010, 12:21 PM
neilw20's Avatar
neilw20 is on a distinguished road
Sub process
Run the text engraving as a sub process and only mirror that process.
Needs a little thought to locate the mirroring point.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 09-03-2010, 12:24 PM
Yeah that's why I pretty much came up with it. Just didn't know if there was an easier/better way. Thanks
Old 09-03-2010, 12:45 PM
neilw20's Avatar
CAM package.
CAM programs can be frustrating.
You might be able to find a font editor that you can make a mirrored font with.
That is if the CAM package can select a font.
ACAD simplex text makes quite a nice engraving font. (IMHO)
Just explode the text.
Offsetting a copy sideways slightly makes it look nice with different width vertical strokes due to double pass.
Those lines are 1mm apart. Done with a dead 0.3mm drill ground flat on the end. Stainless steel. Cutter lasts 12 hours.
Problem- Gcode is mirrored MugenSeiki5T Mach Mill 15 08-06-2010 08:39 AM
Mirrored: What's going on here? Sheridan Basses Musical Instrument Design & Construction 4 05-09-2010 01:00 PM
Work is Mirrored??? keelhauled Post Processor Files 5 03-30-2009 01:38 AM
Axis is Mirrored s3r4ph LinuxCNC (formerly EMC2) 3 09-23-2008 05:21 PM
Output is mirrored?? BobLWeiss Carken Products (Deskam, DeskCNC etc) 3 01-03-2005 11:54 AM
