Old 09-02-2010, 10:28 AM
glsmaverick is on a distinguished road
Variable angle milling head
Hello everyone,
I am an engineer at a company in mid michigan and I am working on a machining project for some shafts that we just recently began making in house. The project is putting a keyway on a tapered shaft with a 5 degree angle. I would like to figure out a way to cut this key way without having to develop complicated fixturing to take the taper out as a factor (lifting the shaft to go from 5 to 0). Is there a variable angle attachment for the HAAS CNC that would allow me to set the mill bit at 5 degrees so that when I run the head up at a 5 degree angle in the program the end of the end mill would be parallel to the face of the shaft?
*Oh; just so you all know a 5-axis table is definitely out of the budget*
Old 09-02-2010, 11:26 AM
KenFoulks's Avatar
KenFoulks is on a distinguished road
Try Big Kaiser
http://www.bigkaiser.com/angle-head-agu.php
Old 09-02-2010, 11:29 AM
Matt@RFR is on a distinguished road
Can you use a keyseat cutter instead of an endmill and machine it from the side?
Old 09-02-2010, 11:36 AM
Keyseat cutter might work
It looks as though that Big Kaiser might work, I gotta read up!
adjustable angle milling head. Beek Cincinnati CNC 1 04-26-2010 11:52 PM
right Angle Head help inkydo69 Mastercam 11 04-08-2009 09:58 AM
variable angle drilling head kendo Haas Mills 21 12-12-2008 10:46 AM
Programing for Right Angle Head bkobernus Haas Mills 16 04-27-2007 05:31 PM
Programming for angle head--G18/G19 Dave L GibbsCAM 3 07-20-2006 10:33 PM
