Old 09-01-2010, 10:04 AM
bushing1 is on a distinguished road
strange hi low gear change solenoid malfunction
We bought a 92 VF-1 fixer upper a few months back with a bad gear box. When we got the machine, the top of the gear change solenoid was disconnected by the previous owner. We found that gear changes would work only if either the top or the bottom of the solenoid was disconnected. High to low or low to high would work this way depending on which side of solenoid was disconnected. Hooking up both wires resulted in no programmable gear changes at all.
Over the last few months we have replaced the gear box, the IO board, the solenoid cable (33-0880A) as well as the hi lo gear change solenoid and still can not hook up top and bottom of solenoid simultaneously with any success. Haas HFO wants to come in for service call at this point and start by replacing entire solenoid manifold assembly. I am a little skeptical that this will solve the problem.
Any suggestions?
Scott
Old 09-01-2010, 08:19 PM
Submitters problem solved.
Note- I spoke to Carlos at Reytech Machine 845-521-6052 www.reytechmachine.com today and he helped me figure out that the top and bottom wires of the solenoid were reversed. Switching out the wires solved the problem. The strange thing was that with the wire reversed I could change gears at all. Problem solved.
Any suggestions?
Scott
Tags
Correcting Gear Change Errors Stupidav Haas Mills 4 05-27-2010 07:22 PM
Need Help!- Having trouble with vf2 gear change Kenneth434 Haas Mills 0 10-12-2009 09:21 PM
Strange Axis problem after Ballscrew Change AKFALAR CamSoft Products 5 07-27-2009 12:21 PM
Change gear set up for threading Turn4fun Mini Lathe 1 11-04-2008 07:19 AM
Quick Change Gear Box larry53 Want To Buy...Need help! 0 05-10-2008 01:23 PM
