Old 08-30-2010, 11:52 AM
dafowfidy is on a distinguished road
92 VF2 Low Spindle Oil
I had a low spindle oil warning, it wasnt in the alarms, show up last night before I powered down. I am guessinf that is was refeing to the gear box and not the spindle. I looked it up in my book and it said to contact your haas tech. I would hate to call someone out just to fill some oil, has anyone had any experience with this?
Old 08-31-2010, 09:32 AM
haastec is on a distinguished road
If you did not get an alarm then it is possible that it was just a maintenance timer that you saw. But if you have not serviced the gearbox oil in some time you may want to do it.
Behind the spindle nose there should be a small cover plate about 4" X 6". Remove this plate and then you should be able to see a drain plug and an over flow drain tube. Take out the drain plug and wait for the oil to stop draining. Reinstall the plug, then at the top of the head you should see a fill port with a spring loaded lid. Fill the gearbox with Mobil DTE 25 or equivelant until oil runs out the overflow tube from below. Once it is full clean up your mess and reinstall cover plate.
Hope this helps.
1992 VF2 Alarm 123 spindle Spindle Drive Fault dafowfidy Haas Mills 15 05-14-2012 01:32 PM
spindle motor and spindle control dont work customcncparts Milltronics 0 10-01-2009 02:08 PM
Sweo spindle drive? new mill dead spindle Shizzlemah Fadal 13 12-18-2008 11:11 AM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 02:49 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
